Focus Dashboard Secret (Trick)
#31
Posted 23 November 2009 - 09:41 PM
#32
Posted 29 November 2009 - 08:46 PM
when i do mine it comes up - r22 and E001 what do these mean ???? then no dtc which i get
thanks
jamie ....
#33
Posted 03 December 2009 - 08:34 AM
hi,
thanks
jamie ....
SNAP!
matt b
just done it on my st170 and its works a treat, although ium not gettin no dtc codes i am getting 2 codes, well i think they are codes coming up before it goes to dtc and they are R22 and E001 does anyone know what these mean
first page last post, same question...I would not worry about it, sometimes to much information gets you worried for no reason......it's like having access to an Enigma machine without having the relevant code book to hand
#34
Posted 07 December 2009 - 12:53 PM
#35
Posted 13 December 2009 - 03:14 AM
#36
Posted 16 January 2010 - 12:19 PM
#37
Posted 19 January 2010 - 12:02 AM
#38
Posted 19 February 2010 - 03:13 PM
I got............... 9359 ..........B1359.......... Ignition Run/ACC circuit failure. wot is this i have just had the engine from a 2004 focus fitted in my car. My car has also lost power it WILL NOT GO FASTER THAN 55MPH. is this due to the code???????????
hopefully your car isnt still running like this but I would have guessed that its in limp home mode, and you need/ed a mechanic to take a look at it!
#39
Posted 17 March 2010 - 03:23 PM
This trick can be found on www.fordst170.co.uk and it does work:
Self Diagnostics Mode
The Self Diagnostics Mode gives you in-depth information about your engine and the actual numbers in digital. To use it, follow the steps:
* Insert Key but do not turn it on
* Press and hold the Trip Meter Reset Button
* While holding the reset button, start your car and continue holding the button
* Within 10 seconds, the display should change to "test" in LCD font and the needles will do a full sweeping. Release the Button
Pressing the button will now cycle through some 17 different modes
* 1.Shows a Gauge Sweep
* 2. Shows all 8's on the LCD (LCD TEST)
* 3. Illuminates all the bulbs on the dash
* 4. Displays hexadecimal value for ROM level
* 5. Displays the hexadecimal value for EE level
* 6. Shows DTC (Diagnostic Trouble Code)
* 7. Digital Speedometer - mph
* 8. Digital Speedometer - kph
* 9. N/A
* 10. Digital tachometer
* 11.Fuel volume
* 12. Engine coolant temperature
* 13. Battery voltage
* 14. ABS fail
* 15. Electronic brake distribution (EBD) failure
* 16. Illumination
* 17. Crank Sense
The listing of the DTC (Diagnostic Trouble Code) from Number 6 above can be found on the DTC Codes page to view the list of codes and its meanings of it.
List of DTC codes can be found here as well: http://www.fordst170...k/dtc-codes.php
#40
Posted 27 March 2010 - 11:26 PM
hi did the self diagnostic test on ROM level got r20. on NVM got E002. on DTC got 9202.it says code 9202 is fuel pump module circuit open is this a failt.it says in the manuel a open circuit mean its workingI use thi trick a lot
to see speed and fuel level
I found one document about it in one brazilian forum of ford's
Self-Diagnostic Mode - Instrument Cluster
1. To enter the instrument cluster self-diagnostic mode simultaneously depress and hold the tripmeter reset button then turn the ignition switch to position II or III.
2. Release the tripmeter reset button when TEST is displayed on the LCD. This will take between 5 and 8 seconds.
3. The instrument cluster will enter the gauge sweep test.
4. To navigate to the following tests while in self-diagnostic mode depress the RESET button to move to the next test.
5. The self-test is deactivated when the ignition is turned to the OFF position.
#.Test
#.Syntax Displayed
#.Gauge/Indicator/Display Tested
#.Description
#.1..Gauge sweep.
#.GAGE.
#.Tachometer, speedometer, temperature and fuel.
#.All gauges go through a full up and down pointer sweep smoothness check, which takes approximately 5 seconds.
#.2..Fill in all LCD.
#.8888.
#.LCD display built into Speedometer.
#.Fills in LCD display therefore seeing if display functioning correctly.
#.3..Indicator bulbs.
#.BULB.
#.Instrument cluster illuminates indicator and warning indicators.
#.Illuminates all the warning indicators that are controlled by the instrument cluster.
#.4..ROM level.
#.rXXX.
#.Instrument cluster read only memory (ROM).
#.Displays the instrument cluster ROM revision level.
#.5..NVM level.
#.EXXX.
#.Instrument cluster non volatile memory (NVM).
#.Displays the instrument cluster NVM revision.
#.6..DTC.
#.XXXX or NONE.
#.Diagnostic trouble codes (DTCs).
#.To list the DTCs stored, press the RESET button.
..REFER to the instrument cluster diagnostic trouble code (DTC) index below.
..The DTC codes will scroll through if there is more than one.
#.7..Road speed mph.
#.XXX.X.
#.Speedometer.
#.Displays the speed signal input in mph.
#.8..Road speed Km/h.
#.XXX.X.
#.Speedometer.
#Displays the speed signal input in Km/h.
#.9..Engine speed.
#.XXXX.
#.Tachometer.
#.Displays the tachometer input signal (RPM).
#.10..Fuel volume.
#.FXXX.
#.Fuel sender system.
#.Displays the fuel volume signal input.
#.11..Coolant Temp.
#.XXXC
#.Engine coolant temperature.
#.Displays the engine coolant temperature signal input.
#.12..Battery Voltage.
#.bXXX.
#.Battery Voltage (t).
#.Displays battery voltage input.
#.13..ABS fail.
#.Ab-[H/L].
#.ABS system.
#.Displays ABS raw cluster input. (H = open-circuit, L = ground).
#.14..Electronic Brake Distribution Failure (EBD).
#.Eb-[H/L].
#.EBD system.
#.Displays EBD raw cluster input. (H = open-circuit, L = ground).
#.15..Illumination.
#.IL-[H/L].
#.Cluster and instrument panel illumination.
#.Displays instrument cluster and instrument panel illumination. (H = ON, L = OFF).
#.16..Crank Sense.
#.Cr-[H/L].
#.Cluster and instrument panel crank sense.
#.Displays Cluster and instrument panel Crank sense. (H = Ignition, L = Ground or over-charging).
#.(Crank sense it the Pos I (Accessory) supply to the cluster. If this is missing then the cluster will remain dead for about 20 seconds after key on. Then it will function normally. This can happen when someone fits a radio and blows the accessory fuse).
Note:
Additional tests are available after number #.16 but are not useful for diagnostics.
Note:
Later vehicles had a "cost reduced" cluster that had a different Engineering Test Mode layout. These came in about 03-53 reg, and can be distinguished by only the symbol lighting up in the tell tale rather than the whole lot. (LEDs rather than bulbs).
These clusters used stepper motors for the gauges rather than the air cored ones and did not have a Gauge Sweep test?
Self ..........DTC.......... Description
Diagnostic
Mode
Displayed
DTC
9202 ..........B1202.......... Fuel pump module circuit open
9204 ..........B1204.......... Fuel pump module short to ground
9342 ..........B1342.......... Instrument Cluster ECU is defective
9317 ..........B1317.......... Battery voltage high (greater than 16V)
9318 ..........B1318.......... Battery voltage low (less than 10V)
A143 ..........B2143.......... NVM memory failure
A477 ..........B2477.......... Module configuration failure
D041 ..........U1041.......... Invalid data for vehicle speed
D027 ..........U1027.......... Invalid data for engine RPM
D073 ..........U1073.......... Invalid data for engine coolant
D262 ..........U1262.......... Missing speed, tacho, engine temp, or dometer count
D123 ..........U1123.......... Invalid data for odometer
#41
Posted 09 April 2010 - 07:10 AM
It returned a DTC code of 9601.
Seems this means:
B1600 9600 PATS Ignition Key Transponder Signal is Not Received - Damaged Key or Non -PATS Key
I had a spare key made up (only 1 key when I bought it) so its probably got something to do with that. Strange tho how the key works 100% ok.
Heres a useful link of more codes in case anyone is interested.
DTC Codes
#42
Posted 16 April 2010 - 07:03 PM
no dtc to report, gr8!!
mine is a 1.8l petrol zetec (56 reg)
#43
Posted 27 May 2010 - 07:42 AM
thanks boys and girls
#44
Posted 27 May 2010 - 10:41 PM
#45
Posted 08 July 2010 - 09:48 AM
Do you reckon it would help me.My fuel and temp gauge are not reading prperly. When I switch the engine off the needles shoot up to half way. Have just fueled up and the gauge does register the fuel amount.But still stayed half way when the engine is off. I'm new to cars with computers in them as I've always had old bangers this is the newest car I've ever had so I'm natually apprehensive about messing with the computer. I have a 2002 1.6l lx focus.
zev x
5 user(s) are reading this topic
0 members, 5 guests, 0 anonymous users
