simonsp Posted August 25, 2010 Share Posted August 25, 2010 Hi everyone!! I have just come across a duratorq 2l diesel 51 plate mondeo with a water leak. It looks as if it is dripping from underneath power steering pump. Am I right in thinking that the water pump or thermostat share the same housing as the power steering pump? If so would a seal have gone in between the two? Or is it more likely that the housing itself would have cracked? Any answers will be greatly appreciated Cheers Simon Quote Link to comment Share on other sites More sharing options...
DAS Posted August 25, 2010 Share Posted August 25, 2010 hi, yes the water pump is run off a shaft from the power steering pump, it is a well known problem that the water pump leaks there. its usually requires a new water pump. hope this has been helpful. Quote Link to comment Share on other sites More sharing options...
