simonsp Posted September 1, 2010 Share Posted September 1, 2010 Hi my aerial has snapped off. How easy is it to change the whole lot? Thanks in advance Simon Quote Link to comment Share on other sites More sharing options...
mintalkin Posted September 1, 2010 Share Posted September 1, 2010 where has it snapped off?, the mondeo aeriel masts should screw off the base, so if there is a bit of the aeriel left you should be able to just replast the mast. Quote Link to comment Share on other sites More sharing options...
simonsp Posted September 1, 2010 Author Share Posted September 1, 2010 where has it snapped off?, the mondeo aeriel masts should screw off the base, so if there is a bit of the aeriel left you should be able to just replast the mast. the aerial is snapped on the screw thread inside the base Quote Link to comment Share on other sites More sharing options...
mintalkin Posted September 1, 2010 Share Posted September 1, 2010 you do not say which mk mondeo you have,heres a guide for the mk3 which will give you an idear of whats involve. http://www.stdrivers.co.uk/forum/showtopic.php?fid/26/tid/2305/ you can get new base from your local dealer http://www.allenparts.com/ford/acatalog/MK3_Ford_Mondeo_Audio.html Quote Link to comment Share on other sites More sharing options...
chris bowman Posted September 1, 2010 Share Posted September 1, 2010 the base is quite easy to fit and i was amazed as to how cheap it was when a vandle broke mine knicking the aerial! Quote Link to comment Share on other sites More sharing options...
GrahamH Posted September 1, 2010 Share Posted September 1, 2010 the base is quite easy to fit and i was amazed as to how cheap it was when a vandle broke mine knicking the aerial! Have you tried drilling into the end of the broken thread and using an eeziout? I think the thread is only brass so should be easy to drill. Quote Link to comment Share on other sites More sharing options...
mintalkin Posted September 2, 2010 Share Posted September 2, 2010 easy to drill, but akward to drill straight when the base is in the middle of the roof. Quote Link to comment Share on other sites More sharing options...
chris bowman Posted September 2, 2010 Share Posted September 2, 2010 i just replaced the whole mount. about 8.50 from fords why waste time? Quote Link to comment Share on other sites More sharing options...
