jmurray01 Posted September 2, 2010 Share Posted September 2, 2010 Here's the story, when the ignition is off and you turn the headlamps on only the O/S goes on and the N/S remains off, however when you turn the ignition on the N/S goes on. Fuse problem ? Is there a seperate fuse for both sides or is it just one fuse ? Quote Link to comment Share on other sites More sharing options...
mintalkin Posted September 2, 2010 Share Posted September 2, 2010 is it the headlight bulb or the sidelight bulb,if its only the sidelight bulb it is most likly a parking light system. Quote Link to comment Share on other sites More sharing options...
jmurray01 Posted September 2, 2010 Author Share Posted September 2, 2010 Hmm... Didn't quite understand that It isn't the bulb, cos it works when the ignition is on. Another quick question: On a MK4 Fiesta should the lights go really dim when the ignitions in the OFF position ? Quote Link to comment Share on other sites More sharing options...
james_60 Posted September 2, 2010 Share Posted September 2, 2010 Hi Sounds like a voltage shortage to N/S headlight (not enoiugh voltage to throw the relay when the ignition is off. What voltage is your battery when everything is switched off. Jamie Quote Link to comment Share on other sites More sharing options...
mintalkin Posted September 2, 2010 Share Posted September 2, 2010 on some ford models there is a parking light system which only puts the offside front and rear lights on, not full or dipped beam but the small sidelight bulb in the front headlight and a tail light. Quote Link to comment Share on other sites More sharing options...
jmurray01 Posted September 2, 2010 Author Share Posted September 2, 2010 So even if this isn't meant to happen as long as the O/S headlamp goes on without the ignition it will pass an MOT ? Quote Link to comment Share on other sites More sharing options...
