Air Con Water In Footwell
3 replies to this topic
#1 Fallguy
Fallguy
    Newbie
  • Pip
  • 9 posts
  • Name: Colt
  • Ford Model: Galaxy Ghia TDCI
Posted 04 September 2010 - 04:53 PM
I have a 2008 Galaxy and the when using the air con after about 20 minutes water comes out of a pipe at the bottom right hand side of the centre console and pours into the driver footwell. This same pipe has air blowing out of it all the time when you have the heater running (even if not using aircon) You would not notice the pipe unless you remove the trim panel at the bottom of the centre console on drivers side. Does any body know what this pipe is actually for? Surely it would not be designed to drain the water from the air con inside the car!
#2 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 05 September 2010 - 08:49 AM
it is the drain for the aircon and is a common problem for it to become dislodged.
#3 Fallguy
Fallguy
    Newbie
  • Pip
  • 9 posts
  • Name: Colt
Posted 06 September 2010 - 08:50 AM
Thanks Mintalkin - Now just need to find where the drain should be connected to. No doubt somewhere difficult!
#4 scheemy
scheemy
    Newbie
  • Pip
  • 8 posts
  • Ford Model: focus
Posted 17 November 2010 - 11:45 AM
That pipe is the condensation drainage tube for the aircon evaporator. It should go through a hole in the bulk head or floor. You might have to jack the car up and have a look around near where the transmission tunnel is.
www.autokool.co.uk
