when driving normally about what revs do you change up? im new to a diesel and not sure how high I should be revving to change gear without putting unnessesary strain on the engine
1.8 Tdci Question
Started by MrrNoName, Sep 06 2010 08:08 AM
4 replies to this topic
#1
Posted 06 September 2010 - 08:08 AM
for all of you with a diesel, esp the 1.8
#2
Posted 06 September 2010 - 09:34 AM
I don't think you can put excessive strain on your engine as the diesels are rev-limited in the ECU. Personally unless I need a bit of urgency I tend to change up at about 2000rpm as the turbo starts to kick in around this figure and I've found that I get better fuel economy by keeping below it in the intermediate gears.
#3
Posted 06 September 2010 - 10:41 AM
could you put excessive strain on your engine by changing too low?
#4
Posted 06 September 2010 - 10:55 AM
I find mine struggles a bit at or below 1000rpm when its cold. Once warm it will pull ok from 1000rpm.
Once again I don't think it will put excessive strain on it - you can easily tell if its struggling and just change down.
I also find that when driving briskly the turbo range is fairly limited and it soon runs 'out of breath' so it's better not to keep it on the boil like a petrol but change up earlier.
#5
Posted 06 September 2010 - 12:14 PM
i change up at 1900 rpm
in petrol i change up at 2100 rpm
