Sign in to follow this
footymad
Courtesy Light
hello everybody
just bought a fiesta zetec 1.6 s 2007 can any-one tell me how to get the bulb compartment out of the courtesy light to change the bulb.tried just pulling it out but jammed in solid. any help would be really grateful
To remove the plastic covering there is a rectangular slot in the plastic towards the windscreen. Stick a screwdriver in here and lever out the cover. it should pull out flat (There is a long plastic leg in each of the 4 corners). Once removed you can easily access the bulb to remove. You can also remove the bulb housing by sqeezing the clips and pulling out. I can provide a more detailed guide if this is tricky to understand :lol:
