Fix Boot Lid Lock Random Opening Problem
23 replies to this topic
#16 Peter N
Peter N
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Peter
  • Ford Model: Focus 1.8 TDCI hatchback
  • Year: 2006
Posted 27 June 2013 - 11:04 AM
Having just completed this repair, thanks to Lippo, I thought I should add something to the topic.
The cause of the problem appears to be,
1 The use of the switch acts like a bellows and sucks air in.
2 As the metal plate cools it allows the water in the air to condense out.
There's not a lot that can be done about 1 but you could replace the metal flap with a plastic one (as I have done). I will check in a few months to see if there is any water there and report back.
Peter
Have something to contribute?
#17 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,961 posts
  • Name: James
  • Year: 2007
Posted 16 August 2013 - 01:11 PM
did you get this repaired again Lippo?
I am due to do mine soon, got to buy the bits for it and need to find a victim mouse! did you have to desolder, or could you get away with cutting the end off and solder a new end to the new switch?
#18 karlgixer
karlgixer
    Member
  • Budding Enthusiast
  • PipPip
  • 15 posts
  • Name: karl
  • Ford Model: focus
  • Year: 2004
Posted 18 June 2014 - 04:20 PM
glad i found this as my boot lock is playing up,
can someone please update the maplin links on page one as not working.
cheers
karl.
#19 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,961 posts
  • Name: James
  • Year: 2007
Posted 18 June 2014 - 08:35 PM
I bought
http://www.maplin.co...le-switch-kr91y
and
http://www.maplin.co...le-switch-kr89w,
cant recall which I used though it was a while ago.
#20 karlgixer
karlgixer
    Member
  • PipPip
  • 15 posts
  • Name: karl
  • Ford Model: focus
  • Year: 2004
Posted 18 June 2014 - 10:24 PM
I bought
and
cheers,
which of the 4 connection points do i solder to?
cheers
karl.
#21 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,961 posts
  • Name: James
  • Year: 2007
Posted 19 June 2014 - 11:37 AM
If you look at the bottom of the switch you will see them.
It will show a line going from one pin to another, I cant recall if its next to each other or opposite, but it will be like this:
*__*
 __
or
each * is the leg, so you just follow it, the switch connects each of the connected stars.
#22 Dee_82
Dee_82
  • 904 posts
  • Name: Darren
  • Ford Model: Focus MK2.5 1.6 TDCI
Posted 23 July 2014 - 07:20 PM
hi there folks been having some issues myself an thought id see if you guys have any thoughts.
so the switch stopped working, I was doing some work on the rear tail lights at the time so there is a possibility something may have gone a bit wrong but as far as I can tell everything was isolated.
anyhow, the remote unlocks the tail gate work but the switch doesn't.  there are two feeds going in to the switch, a neutral and a 12v live (white).  the switch is off by default and when pushed in creates continuity so as far as I can tell that switch should be working.
tracing the 12v live (white) back in to the boot it runs off towards the front of the car,
the neutral follows the same path and joins up with a netural from the reg plate lights and tail gate lock, and wiper motor all maintain continuity.
my guess is that white from the switch runs off to some sort of control but at this point im stuck, I cant see any mention of a fuse or a relay in Haynes but with power going to it im a little stumped.
soo does anyone have any ideas?
edit, bugger, just realised im not on the focus sub forum! oops! ah well it should be much the same setup...
#23 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 20,961 posts
  • Name: James
  • Year: 2007
Posted 24 July 2014 - 11:37 AM
Hi Mate,
They are pretty much the same setup any Ford these days.
It sounds like your switch has probably given up the ghost. I think the white line goes off to the gem and powers the boot switch, but its a small enough current that whatever you did probably was not to blame.
I would say pop the plastics off the car, and remove the switch, short these two wires out and the catch will probably click as you expect it to, then you can just fix it from there :)
#24 solar
solar
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Name: Francis
  • Ford Model: S Max
  • Year: 2012
Posted 08 March 2015 - 05:50 PM
Have just repaired the switch on an S-Max and there are some differences from the above pictures, but the general repair strategy works.
Differences:
  • Instead of a standard miniature microswitch the original used a tactile switch like the ones recommended here for the replacement. This makes it easy to unsolder it and drop in a replacement of the same 6 x 6mm size.
  • Has a connector to detach the loom.
  • No hole through case for the wires.
  • The 2 halves are screwed together and the screws seems quite loose so I assume the water entered through the rubber seal
3 things to watch:
  • Don’t overtighten the screws as it distorts the plastic and stops the switch clicking. Check it is clicking well as you tighten the screws and clip it back into its surround. May need to shorten the button to get it to work well.
  • I think the reason people above find their repair did not last is that the original switch is arranged such that when the finger has fully pushed the operating bar it presses on the case of the switch so the full force of the finger is not on the switch button itself. These are only tiny switches so should not be pressed hard on the button. When selecting a replacement find one that clicks over and then the button goes flush with the case. If the button still sticks out it could fail after some use due to the heavy force on the button. Tactile switches come in a vast range of button lengths and you can clip off the excess, file it down or melt it down with a soldering iron. http://www.maplin.co...le-switch-kr88v is the Maplin one with shortest button but still too long.
  • When removing the trim with reversing lights and switch pull it straight in direction of the 4 mounting bolts. I broke some of the plastic by failing to do this. It does take a lot of pulling. It is possible that the switch comes out without removing the trim if a small screwdriver can be wormed in to release the catches on the switch but did not try it. Saves having to pull the interior trim off which leaves a load of clips scattered about and needing a magnet to retrieve them. Wiper motor had to come off too.
This switch was filled with white grease around the switch. Not sure what it is there for so did not put new grease in as not sure these tactile switches will survive grease ingress.
Of course if this repair is beyond you there is a quick fix which is to snip one of the wires and insulate the ends. This stops the switch randomly unlocking the boot but the remote enables it to be opened.
All seems like poor original design to me to use such a tiny switch for this purpose. One drop of water inside it will kill it.
Not what you're looking for?
