Parking Sensors - MK2 1.6 Ghia Focus
Started by anachorai, Sep 18 2008 03:14 PM
7 replies to this topic
#1
Posted 18 September 2008 - 03:14 PM
If anyone can help? I have just picked up a MK2 1.6 Ghia Focus. It has the Parking Lights option. However, when I activate it, the head lights go off and nothing seems to happen when I reverse of get within a metre or so from an object. Even thought the option is on the dial and the head lights go off, does this model have parking sensors. I cant see anything on the bumper or rear of the car.
Thanks for your help.
#2
Posted 18 September 2008 - 03:58 PM
Welcome to the club
Parking lights are not parking sensors. Parking light is just putting your sidelights on for when you are parked up, so that you are visible in restricted visibility conditions.
#3
Posted 18 September 2008 - 04:11 PM
As said, parking lights and parking sensors are 2 very different things. Usually with the parking lights you put the indicator on after you have turned the engine off as to whatever side is on the road, and that sidelight will stay on so no one will drive into you.
#4
Posted 18 September 2008 - 05:16 PM
Many thanks. Shame the steering cannot be sniffened, what model would i need to be able to change the set up from Normal to sport, or is it an optional extra? I thought the Ghia (its my first Ford) had everything as standard?
#5
Posted 18 September 2008 - 05:20 PM
you will find that switching the parking lights on by turning the headlight switch will put the sidelights on but switch the dash lights off to save power,the titanium x is the fully loaded model
#6
Posted 19 September 2008 - 08:29 AM
I'm not sure how the models of fords work as the have so many different versions but i also thought the ghia was a mid range version.
#7
Posted 19 September 2008 - 08:34 AM
the ghia has now been replaced by the titanium and titanium x
#8
Posted 21 September 2008 - 10:06 AM
I was looking for a Focus Ghia but got fed up of trying to find one without coroded alloys. In the end I got a black Zetec which has the nice feature of having had parking sensors added as an option.the ghia has now been replaced by the titanium and titanium x
Does anyone know how to remove the door panel/trim on the front doors as there is a very annoying creaky noise coming from it.
