Clunking Noise From Front
12 replies to this topic
#1 mick88
mick88
  • 125 posts
  • Name: Mick
  • Ford Model: Fiesta Zetec 1.25 3dr Mk7
Posted 16 September 2010 - 10:06 PM
Hello All
Fiesta has been behaving well until lately
When turning the steering to straight ahead after turning when reversing I get a clunking noise from the front, steering is quiet at all other time's, is this just the norm for the electric steering system as i've no experience of it or is it a characteristic of the Mk7 fezza :D
Thank's in advance
#2 jmurray01
  • 639 posts
  • Name: Jamie
  • Ford Model: MK4 Fiesta 1.25i Ghia in State Blue
  • Year: 1997
Posted 17 September 2010 - 02:42 PM
Sounds like the strut bearing. The strut bearings job is to twist the suspension strut when the wheel turns, when it goes bad, you rotate the wheel to straight ahead and the suspension coil doesn't twist back with it, so when the strut turns the clunk sound is the strut rotating but the coil staying in the same position. Hard to explain but hope I have done so adequately.
#3 mick88
mick88
  • 125 posts
  • Name: Mick
Posted 17 September 2010 - 02:56 PM
Thanks jmurray01 for your reply
Was told could be the top strut mounting, is this the same thing. Just strange that I get it only when reversing but not at all when driving
Will book a date with Ford for a look at it
#4 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 17 September 2010 - 02:59 PM
yes, although i would say the mounting 'holds' the bearing within it but yes that is what they are talking about.
#5 Focus_ST-3
Focus_ST-3
  • 615 posts
  • Ford Model: Mk2
Posted 17 September 2010 - 03:05 PM
iv got this problem as well. started after about 14000 miles. only happens in slow speed manouvoures usinf full lock. Took it to Ford who lubricated the steering column, the problem still persists though.
#6 stef123
stef123
  • Management
  • 3,577 posts
  • Name: Stef
  • Year: 2006
Posted 17 September 2010 - 03:07 PM
only time ive ever come across it is on older cars, after a few years of being blasted by water and salt, the bearing dries up.
i would have said it was unusual on such a new car but then, who knows these days.
if you get someone to turn the wheels, have a look at the spring you might see that its 'notchy' when turning, you might also be able to feel it.
#7 mick88
mick88
  • 125 posts
  • Name: Mick
Posted 17 September 2010 - 03:46 PM
Thank's all for the replies
Stef will check out the spring's condition
Car only has 5000 mile's on it from January this year but it was built last August so was probably lying in a compound somewhere for the 5 month's that hasn't helped :(
#8 oobster
oobster
    Member
  • PipPip
  • 22 posts
  • Ford Model: Focus
Posted 22 September 2010 - 09:24 AM
Hi Mick88
Did you get any resolution to this problem?
My Mrs 10-plate Titanium is doing the same - a knocking noise from the front end when reversing then straightening the wheel again at low speeds. It is fine when above 10mph. The car has only done 4000 miles.
Cheers
oobster
#9 mick88
mick88
  • 125 posts
  • Name: Mick
Posted 23 September 2010 - 12:14 AM
Hello oobster
Fiesta is booked into local Ford dealer this coming friday morning, will report back any news when I get it back. Hopefully get it sorted
#10 oobster
oobster
    Member
  • PipPip
  • 22 posts
  • Ford Model: Focus
Posted 23 September 2010 - 06:12 PM
Thanks, that would be appreciated.
#11 mick88
mick88
  • 125 posts
  • Name: Mick
Posted 24 September 2010 - 10:39 PM
Got the Fiesta back today, noise gone :D
Noise was being caused by the torque sensor that control's the electric power steering. It was giving wrong infomation to the steering's ECU, it's job is to sense the steering input and vehicle speed and adjust the strenght of the steering to match, light steering at slow speed's and weighting up when the speed increase's. They updated the system's software and also checked the suspension and steering part's, all checked out ok
#12 oobster
oobster
    Member
  • PipPip
  • 22 posts
  • Ford Model: Focus
Posted 24 September 2010 - 10:58 PM
Thanks Mick, did the noise I described above sound similar to the problem you were having?
Also, was there any charge for the work you got today?
#13 mick88
mick88
  • 125 posts
  • Name: Mick
Posted 24 September 2010 - 11:36 PM
Yes mate same noise when straightening steering after reversing, no noise when up and running, only at slow speed
No charge for the work, done under warranty
