joolstdi Posted September 18, 2010 Share Posted September 18, 2010 Hi this is my first time on here, and i have some question to you all for my fusion 1.4 tdci 04 plate. 1/ I'm having problems with the front driver seat, it's make a slight clicking noise when I turn left, I have greased and oil frame but it seams to be coming from inside the upper part of the seat, which i can not get into, do i go to the dealers or a seat specials or do any of you know of a problem on these seats!! 2/there is a clicking noise coming from under the dash when i start the car from cold. I thought it was the fan but i turned this off, then i thought it was the radio cd i turned this off, I'm thinking it might be some sort of relay clicking, can you shed some light on this please. 3/ the heater plugs glow light on the dash does not go ON at all when i start the car!! on my last car a vw it was showing for a few seconds and going out. Sorry for all of these question, please read and reply. joolstdi Quote Link to comment Share on other sites More sharing options...
skyman114 Posted September 18, 2010 Share Posted September 18, 2010 Hi this is my first time on here, and i have some question to you all for my fusion 1.4 tdci 04 plate. 1/ I'm having problems with the front driver seat, it's make a slight clicking noise when I turn left, I have greased and oil frame but it seams to be coming from inside the upper part of the seat, which i can not get into, do i go to the dealers or a seat specials or do any of you know of a problem on these seats!! No idea, a seat specialist would be my choice ! 2/there is a clicking noise coming from under the dash when i start the car from cold. I thought it was the fan but i turned this off, then i thought it was the radio cd i turned this off, I'm thinking it might be some sort of relay clicking, can you shed some light on this please. Mine does not do this??? 3/ the heater plugs glow light on the dash does not go ON at all when i start the car!! on my last car a vw it was showing for a few seconds and going out. Now this one i do know...:) It has to be really cold for the glow plug light to come on !! Hope that helps :) Quote Link to comment Share on other sites More sharing options...
joolstdi Posted September 19, 2010 Author Share Posted September 19, 2010 Thats 1 question down and 2 to go. It look like the glow plug light does not light until it goes under -1 the noise inside the dash, i will try and record. an update on the seat i have re cleaned the old white grease i put on, and heat gun the plastic on the grey side case by the elevation handle in case it was the plastic to try and get it back to its original shape. will keep you updated on progress. joolstdi Quote Link to comment Share on other sites More sharing options...
joolstdi Posted September 21, 2010 Author Share Posted September 21, 2010 Thats 1 question down and 2 to go. It look like the glow plug light does not light until it goes under -1 the noise inside the dash, i will try and record. an update on the seat i have re cleaned the old white grease i put on, and heat gun the plastic on the grey side case by the elevation handle in case it was the plastic to try and get it back to its original shape. will keep you updated on progress. joolstdi Quote Link to comment Share on other sites More sharing options...
joolstdi Posted September 21, 2010 Author Share Posted September 21, 2010 Just an update. the noise clicking is comeing from the radio it sounds like the cd turning !! I have just bought a secondhand seat to try to see if the noise has gone. will keep you informed on that. The clutch is very light and bites right at the top is this normal!!! joolstdi Quote Link to comment Share on other sites More sharing options...
joolstdi Posted September 22, 2010 Author Share Posted September 22, 2010 Just an update. the noise clicking is comeing from the radio it sounds like the cd turning !! I have just bought a secondhand seat to try to see if the noise has gone. will keep you informed on that. The clutch is very light and bites right at the top is this normal!!! joolstdi UPDATE THE CLICKING NOISE WAS THE SEAT FRAME, I HAVE PUT IN THE SECONDHAND SEAT AND NO NOISE AT ALL. I HAVE CONTACTED THE SEAT SPECIALS TO CHANGE THE ORIGINAL SEAT COVER OVER FOR NEXT WEEK. THE NOISE IS COMEING FROM THE RADIO, I WILL BE BUYING A SECONDHAND RADIO WITH A CODE WHEN I INSTALL THE PARRAT HANDS FREE KIT. Quote Link to comment Share on other sites More sharing options...
