Squeaky Gear
4 replies to this topic
#1 zev
zev
  • New Member
  • 152 posts
  • Name: Ibolya
  • Ford Model: focus i.6L lx petrol
  • Year: 2002
Posted 19 September 2010 - 10:10 PM
I've noticed the last few weeks that when I change into 4th gear it squeaks, I have no problems changing gear the gears appears to be running smooth. Is it something to worry about or perhaps it needs a bit of grease.
zev
Have something to contribute?
#2 darrensmith
darrensmith
  • New Member
  • 33 posts
  • Ford Model: focus 1.8 estate
Posted 20 September 2010 - 06:55 AM
zev
hi zev.
do you know what squeaks. is it inside the car, out side,? i had a annoying squeaking from my gear stick, over the years the dust/dirt and liquid from the cup holders had fallen through the gear stick gator and surround, i gave it a hoover and dropped a few drops of bicycle oil on the ball joint at the bottom, seems to have done the job for now.
try and be as descriptive as you can when posting, it will help others to help you quicker.
you can check this by sitting in the car with engine off. move through the gears see if the squeaking is coming from the gear stick.
let me know it is and i will put together a "how to clean post" its really easy to do.
if its not coming from there, repost with a bit more information, im sure one of the members will be able to help you.
hope this helps
Darren
#3 zev
zev
  • New Member
  • 152 posts
  • Name: Ibolya
  • Year: 2002
Posted 20 September 2010 - 10:00 AM
hi zev.
hope this helps
Darren
Yes sorry lol.I've done as you said sat in the car and tested the gears. It very quietly squeaks in all gears but louder in reverse and 4th. Its from the gear stick and inside the car. My gear stick is covered by material and not easy to get to from inside. Hope that describes the problem better .
zev
#4 darrensmith
darrensmith
  • New Member
  • 33 posts
Posted 20 September 2010 - 05:50 PM
zev
ok ill put a read through together for ya now
remove the plastic trim that the leather gator is attached to
lift the trim and gator up out of the way
clean up and mess, dust etc, be careful not to got to hard as you dont want to damage anything. be aware that there are some important electrical stuff there.
then add a few drops of light oil etc. work the gear stick until the squeak is gone (hopefully).
there are a few other plastic linkages there if the squeak is coming from them u can always dab them a bit of oil/grease with a cotton bud.
try not to use to much on the gearstick ball joint just a few drops and work the stick you dont want it swiming in oil just enough to reduce wear.
hope this helps
#5 zev
zev
  • New Member
  • 152 posts
  • Name: Ibolya
  • Year: 2002
Posted 20 September 2010 - 10:33 PM
hope this helps
Thanks darren will give that a go
zev
Not what you're looking for?
