Double Question, Hopefully Simple.
3 replies to this topic
#1 cruisindub
cruisindub
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: 86 Sierra 1.8
Posted 20 September 2010 - 08:35 AM
Hi all,
1st time poster, and after some simple advice, ......hopefully.
I have an 86 Sierra, 1.8 4 dour hatchback. Well, its my wifes car.
Unfortuantely is 600km away from my work where I stay mostly so I dont get to spend alot of time with it. (I do try to care for it best I can with TLC) My wife has told me that we are due the CT (control Technique) equivalent of MOT.
Since I am taking a work day off to srive the 600+km to France to work on the car and then take it to the CT garage, I dont have a lot of time to view the car and spend time searching, so hopeing for some simple answers from forum memeber. (Thanks in advance)
I am told the horn has stopped working, which I presume is a simple fuse. ??
-Where would I find the fuse for this? Is the panel easily removable/any tricks to do this? Where is the actual horm located?
-also tail lights have a fault,when outting foot on brake pedal, one light goes out and works the indicator light. I presume this is some corrosion to the wiring or lights wiring plug connection, anybody had this happen before? Are the wires colour coded and could I 'easily' bypass this connection and connect all wires individually?
Any help appreciated and Thanks to all in advance.
Much appreciated.
Cheers, CruisinDub
Have something to contribute?
#2 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 20 September 2010 - 01:55 PM
the fusebox should be under the bonnet and will have a plastic cover on it with all the fuse locations marked, the rear light problem will be a bad earth to the lights, remove the earth wire from where it attaches to the body and clean the connections, this should cure your light problem.
#3 cruisindub
cruisindub
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 20 September 2010 - 02:52 PM
Thanks for your fast reply.
Will the earth wire be 'obvious' or something I should look out for especially? (ie green/yellow wire)
Are all fuses under the bonnet/plastic cap?
Thanks again in advance.
#4 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Year: 2006
Posted 21 September 2010 - 03:10 PM
as far as i remember all the fuses are in the one fusebox,
the earth wires should be obvious,if cleaning does not sort them out add some supplementary earths.
Not what you're looking for?
