Cortexx Posted September 26, 2010 Share Posted September 26, 2010 Hey All, Finally got my Fiesta Titanium with a abit of Zetec S Styling... I'm thinking of getting the illuminated gear stick and scuff plates from Ford, but as they require power to work, i don't think i will be able to fit them myself. How much do you guys reckon ford will charge to fit both items? Thanks Quote Link to comment Share on other sites More sharing options...
fordpartsman Posted September 26, 2010 Share Posted September 26, 2010 gear stick is a piece of pi&& to fit, and iirc the scuff plates plug into the existing loom, i.e there are sockets under the carpet for them Quote Link to comment Share on other sites More sharing options...
iNath Posted September 26, 2010 Share Posted September 26, 2010 And the scuff plates are like £230! Too much money to burn you... Quote Link to comment Share on other sites More sharing options...
Cortexx Posted September 26, 2010 Author Share Posted September 26, 2010 Heh they are expensive i have to admit, if the loom is already present then great, ill probably give it a go myself! Cheers :) Quote Link to comment Share on other sites More sharing options...
fordpartsman Posted September 26, 2010 Share Posted September 26, 2010 lift the side of the carpet, along the door and check if its there first Quote Link to comment Share on other sites More sharing options...
will-91 Posted September 28, 2010 Share Posted September 28, 2010 ford were looking for 160 pound to fit the illuminated scuff plates, were saying it could affect my warrenty if i wasnt to get it fitted with them, they talk so much !Removed! Quote Link to comment Share on other sites More sharing options...
fordpartsman Posted September 29, 2010 Share Posted September 29, 2010 are they insane Quote Link to comment Share on other sites More sharing options...
mark t Posted October 22, 2010 Share Posted October 22, 2010 I've had the sills off both sides, and there doesn't seem to be a socket to plug in to. I was looking at the gear knob on eBay, and have removed the gear stick surround, and there doesn't seem to be anything there, unless I can get power from the power socket located down there. Quote Link to comment Share on other sites More sharing options...
fordpartsman Posted October 22, 2010 Share Posted October 22, 2010 the gear knob has to wired into the gem module wiring Quote Link to comment Share on other sites More sharing options...
mark t Posted October 23, 2010 Share Posted October 23, 2010 I've now located that! Cheers Quote Link to comment Share on other sites More sharing options...
itsrelfy Posted October 23, 2010 Share Posted October 23, 2010 Where is the gem module on the mk 7 fiesta anyway??? Quote Link to comment Share on other sites More sharing options...
Mk7_Rbj Posted October 23, 2010 Share Posted October 23, 2010 what is a 'gem' module? Quote Link to comment Share on other sites More sharing options...
mark t Posted October 23, 2010 Share Posted October 23, 2010 this thread should tell you what the GEM is, and how to find it, bit of a contortionist to get to it, or take the glove box out! http://www.fordownersclub.com/forums/index.php?showtopic=8978&st=30 1 Quote Link to comment Share on other sites More sharing options...
gazza81288 Posted October 23, 2010 Share Posted October 23, 2010 Wheres the socket located to plug the sills into? i have had a look underneath the carpet and there is nothing cheers Quote Link to comment Share on other sites More sharing options...
mark t Posted October 26, 2010 Share Posted October 26, 2010 FAILED!! Knob arrived today, so set about fitting it, couldn't get it to wire up, so gave up and screwed it on, then had the idea that I could get it to the light switch, but then thought about the led in the lower recess, but took the whole fascia off, and unscrewed the knob to get the surround off, and found while twisting it on, the cables snapped just out of the knob, and I have a hole now in my stick leather! Quote Link to comment Share on other sites More sharing options...
dannyhilton Posted November 13, 2010 Share Posted November 13, 2010 FAILED!! Knob arrived today, so set about fitting it, couldn't get it to wire up, so gave up and screwed it on, then had the idea that I could get it to the light switch, but then thought about the led in the lower recess, but took the whole fascia off, and unscrewed the knob to get the surround off, and found while twisting it on, the cables snapped just out of the knob, and I have a hole now in my stick leather! Exactly the same happened to me *doh* I've had my illuminated gear lever and door sills on for about a year, never connected them up to the GEM though. Took me forever to find the GEM and after looking at all the wires, thought it best to not touch it (Christ knows I made a mess of fittings the parts, I'm no handy man!). Quote Link to comment Share on other sites More sharing options...
