Oil Problem
9 replies to this topic
#1 CBracing
CBracing
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Ford Model: 1.6 focus
Posted 06 October 2010 - 09:00 PM
Hi all
Can anybodie help me with our 1.6 Y reg focus with only 64000 miles, when left ticking over or in heavey traffic it starts smoking from the exhaust.
If you rev it it clears then slowly comes back, I have changed the oil 5w 30w and filter, replaced the engine emissions pipes and valve cleaned out the plate and cover, over the weekend i did a compression check they were between 195/205 psi, also i have replaced the valve stem seals and head gasket this was done because when changing down the gears it smoked when you pushed the throttle.
Has anybody had the same problem or should i replace the oil with 15w 50w.
Please can any one help.
regards C Brooker
Have something to contribute?
#2 tommy.h
tommy.h
  • Budding Enthusiast
  • 251 posts
  • Name: tom
  • Ford Model: mondeo 2.0 diesel mk4
  • Year: 2007
Posted 07 October 2010 - 06:42 PM
Hi all
regards C Brooker
Hi CBrooker
are you sure this is not just codensation caused by the recent cold weather(are you actually using any oil)?
having to top it up.
tom
#3 CBracing
CBracing
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 07 October 2010 - 08:14 PM
Hi CBrooker
tom
Hi tom
Yes matey having to top up now and again its blue smoke coming out. Im looking at a engine strip and clean poss stuck oil rings letting the oil by only when hot.
I have been told to change the oil from 5w 30w to 15w 50w.
clive.
#4 tommy.h
tommy.h
  • 251 posts
  • Name: tom
  • Year: 2007
Posted 08 October 2010 - 06:32 AM
Hi tom
clive.
Hi CBracing
would not go as far as 15w/50 bit to thick. maybe try 10w/40 first also a petrol additive to clean the gum from the rings.
let me know how you go on.
tom
#5 stef123
stef123
  • Management
  • 5,870 posts
  • Name: Stefan
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 08 October 2010 - 11:34 AM
the 1.6 is well known for its oil burning, mine included. how much oil are you using? i probably use 1L or slightly more every 1000 miles. to me, i would rather keep filling it with oil than attack the engine with spanners and a whole load of money - atleast until it gets worse. if i rev the car hard, i can see clouds of blue smoke in the mirror, under normal driving i cant see any although it is using oil still.
#6 javedjee78
javedjee78
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: Liana
Posted 09 October 2010 - 03:31 AM
You are so right
#7 CBracing
CBracing
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 10 October 2010 - 09:31 PM
Hi mate ya it is using about 1lt in a month but no show when driven hard, Im going to replace the oil for 10w 50w or 15w 50w to see what happens. I will also try not at the same time petrol/injector cleaner and will post the results.
Thanks all for you replies, Clive.
#8 stef123
stef123
  • Management
  • 5,870 posts
  • Name: Stefan
  • Year: 2006
Posted 10 October 2010 - 11:48 PM
i would seriously think twice about changing to such a grade of oil, that could only spell disaster for the engine :(
#9 tommy.h
tommy.h
  • 251 posts
  • Name: tom
  • Year: 2007
Posted 11 October 2010 - 08:00 PM
Hi CBracing
10w/40 semi synth is listed as an alternative in moderate climate.
15w/50 is not listed at all so could seriously damage your engine.
tom
#10 CBracing
CBracing
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 11 October 2010 - 09:24 PM
Hi CBracing
tom
Cheer tom ill go for the 10w 40w semi and see what happens.
regards CBracing (clive)
Not what you're looking for?
