Snowfoaming...
Started by Cortexx, Oct 16 2010 07:31 PM
8 replies to this topic
#1
Posted 16 October 2010 - 07:31 PM
Hey All,
Ive been thinking about snowfoaming my car as part of its wash, my question is do you guys think this is a good idea?
And also do i just need the following products to start? (I always have a Karcher power washer)
http://www.cleanyour...s/prod_371.html
http://www.cleanyour...e/prod_516.html
Is that it or do i need more?
Thanks!
Thanks!
#2
Posted 16 October 2010 - 08:17 PM
Thats all you need yes, remember to select the correct fitting though!
I don't own a snow foam lance, cant see it being worth £50+ and have heard lots of people who see no difference in using it. I think its just a gimmick to make washing the car fun
If it was cheaper i would have one ... but not at that price. My suction pipe on my washer does the job to pull through some bubbly shampoo as a pre wash
#3
Posted 17 October 2010 - 02:36 PM
Do you mean a washer bottle like this - http://cgi.ebay.co.u...4#ht_500wt_1156
Would that basically to the same thing but it would take more time to cover the whole car? If so then that might be the best option for me
Cheers!
Cheers!
#4
Posted 17 October 2010 - 02:38 PM
#5
Posted 17 October 2010 - 05:59 PM
The Halfords foam lance is rubbish with snow foam - if you're going to do it then use the proper kit from CYC or similar.
Before I lost the use of an outside tap - I was a big fan of snowfoam. It makes the wash process much simpler and further reduces the risk of damage to the paint that good wash technique introduces.
#6
Posted 21 October 2010 - 06:11 PM
Hi Dan, Took your advice and today buy a proper foam lace nozzle + bottle and 1 litre of snow foam solution. It was around the £50 mark which is expensive, but at the same time I love my car, and want to look after the paint as much as possible, especially now that the winter is coming, wont be long before the horrible grit arrives
Ive never snowfoam'd before... so do you have any tips for a novice like me?
Do i just go straight ahead and snowfoam the car as a pre wash, or so i powerwash it like normal first and then snowfoam it?
Cheers!
Cheers!
#7
Posted 21 October 2010 - 09:19 PM
I've never used one before but I do believe you spray straight on and let it do its stuff for a bit and then rinse off. You may need to have a few experiments with different mix ratios as well to find which gives the best clinging effect. Im sure Dan will help you out with the ins and out
#8
Posted 22 October 2010 - 08:26 AM
The key thing with snow foam is to NOT rinse the car before hand. You want the foam to cling and then take dirt with it as it drops off - if the paint is already wet it won't cling and so will be less effective.
#9
Posted 22 October 2010 - 02:17 PM
Gotcha
Now I just wish DHL would hurry up and delivery the !Removed! thing!
