Freedom10 Posted October 25, 2010 Share Posted October 25, 2010 Hello all, Im new, so sorry if this is in the wrong section. I recently bought a 2006/07 Ford Fiesta Freedom - it does not have aircon/heated front windscreen. A chip in the windscreen cracked (should've gone to autoglass!) so it needs replacing. My question is, if I spend out a bit more money on a heated front screen, is it possible to retro fit it to my car? Is all the wiring there in the dash? I note there is a redundant space next to the button for the rear heated screen where the button for the front heated screen goes, so just need to get a button from Ford. Anyone done this before? thanks for your help. Quote Link to comment Share on other sites More sharing options...
Freedom10 Posted October 26, 2010 Author Share Posted October 26, 2010 Anyone? Quote Link to comment Share on other sites More sharing options...
Dan62 Posted October 26, 2010 Share Posted October 26, 2010 On previous Ford's I've owned none have had the additional wiring installed. Check the fuse locations (F42 & F43 I think and the relay location R164) for pins, if they have put the connectors in the fuse box then maybe the wiring will be there too. I did did manage to fit a heated front screen to my 1990 Fiesta 1.1 Ghia (it was not available on the 1.1) my friend who worked at Ford Dunton got me the wiring diagrams and I purchased the relay, switch & screen. Was a fairly simple job but because the wiring was not installed I could not fit the relay in the fuse/relay box. I also fitted a rear delay wipe to my 1989 Escort. Quote Link to comment Share on other sites More sharing options...
