Help, Please
2 replies to this topic
#1 Shaggyboris
Shaggyboris
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: Focus
Posted 03 November 2010 - 08:15 PM
Hello,
Does anybody recognise these symptoms?
1. speedometer stops working or flies around the dial.
2. power loss of 1000-2000 revs.
3. digital display shows dashes.
It's been suggested that it could be a fuel sensor or gearbox sensor. I'm pretty green with mechanical issues so I'd appreciate some thoughts
Cheers
Tom
Have something to contribute?
#2 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 8,006 posts
  • Name: arthur
  • Year: 2006
Posted 03 November 2010 - 09:08 PM
Hello,
Cheers
Tom
the speedo can be the v ss sensor on the gearbox however the dashes and sweeping dials can also indicate bettery issues or incorrect battery must be silver calcium or a double calcium battery it can take a while to show as the battery has to boil up the acid first try the dash test and see if any fault codes show up key in ignition but dont start the catr hold down the miles reset button on the speedo keep it held in and start the car test will appear now let go of the button each press takes you through the menu look for dtc and write down the codes also check b- which is battery voltage
#3 H3lly
H3lly
  • New Member
  • 282 posts
  • Name: k
  • Ford Model: Mk1 Focus
  • Year: 2003
Posted 04 November 2010 - 12:29 AM
It can also be the CHT sensor, the cable in between spark plug leads. Just make sure it is separated from the ht leads as it cause the voltages to fluctuate.
Not what you're looking for?
