zetec125 Posted November 5, 2010 Share Posted November 5, 2010 i purchased a bee sting aerial for my fiesta but it wont screw onto the base i got two adaptors with the aerial i take it i will have tro take the original screw adaptor out to get my bee sting to fit Quote Link to comment Share on other sites More sharing options...
charlotteee_x Posted November 7, 2010 Share Posted November 7, 2010 The Ariel screw will alreadg be attached to the bit on your car roof so if your Ariel is anything like mine then you just take all the bits off the bee sting arial so all that is as the bottom is just the thread for it to screw directly onto the car. Hope this helps Quote Link to comment Share on other sites More sharing options...
artscot79 Posted November 9, 2010 Share Posted November 9, 2010 The Ariel screw will alreadg be attached to the bit on your car roof so if your Ariel is anything like mine then you just take all the bits off the bee sting arial so all that is as the bottom is just the thread for it to screw directly onto the car. Hope this helps you can make the original a beesting all you do is take the rubber tip off it just pulls off and then using a good hacksaw chop the ariel down to size dab a bit of glue on the rubber cap and replace job done and it will fit Quote Link to comment Share on other sites More sharing options...
Gazjs Posted November 9, 2010 Share Posted November 9, 2010 you can make the original a beesting all you do is take the rubber tip off it just pulls off and then using a good hacksaw chop the ariel down to size dab a bit of glue on the rubber cap and replace job done and it will fit Went down this route, cut 20cm off it, works a treat Quote Link to comment Share on other sites More sharing options...
Nico. Posted November 11, 2010 Share Posted November 11, 2010 i got a richmond on, works sound and looks a treat rather than the tv transmitter i had Quote Link to comment Share on other sites More sharing options...
