Electrics Issue
5 replies to this topic
#1 monty187
monty187
    Member
  • New Member
  • PipPip
  • 27 posts
  • Ford Model: 2.0 TDCI TITANIUM 2005
Posted 22 November 2010 - 02:30 PM
Hello All,
I am having an issue with my 2.0 2005 Titanium Focus. It started a few weeks back and began with the central locking not working everytime. With the fob or key in lock. After a few attempts the key opened the door. But only the drivers. After this brake warning lights and engine warning lights have been on a few times. Finally now the indicators are not turning on. Any ideas what is going on here? Anyone every had an issue like this? I have tried another keyfob with no sucess.
Cheers
Monty
Have something to contribute?
#2 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,889 posts
  • Name: arthur
  • Year: 2006
Posted 22 November 2010 - 04:16 PM
Hello All,
Cheers
Monty
diagnostics is the best bet here check under pass side for water ingress and check in the boot behind the arch cover theres 2 multi plugs there if you have a leak from the boot hinge rubber it goes down into this plug which runs lights indicators etc to the rear other then that check all fuses in the glovebox
#3 monty187
monty187
    Member
  • New Member
  • PipPip
  • 27 posts
Posted 22 November 2010 - 04:49 PM
Thanks a million for that, ill have a look round those things tomorrow in daylight and let u know how it goes. Thanks again :D
#4 monty187
monty187
    Member
  • New Member
  • PipPip
  • 27 posts
Posted 23 November 2010 - 12:49 PM
Think I may have figured it out, partly anyway. I replaced a bulb last week, when I took it out again the locking and indicators are now working. will get a diff bulb and see if that solves it.
#5 artscot79
artscot79
  • PipPipPipPipPip
  • 7,889 posts
  • Name: arthur
  • Year: 2006
Posted 23 November 2010 - 02:30 PM
cant see why that would make a difference unless its the incorrect non compatible bulb i suppose its worth a try
#6 monty187
monty187
    Member
  • New Member
  • PipPip
  • 27 posts
Posted 23 November 2010 - 10:30 PM
Changed the bulb again and everything worked ok until I restarted the car. Now central locking screwed and indicators not working. Will ring the mechanic tomorrow. Cheers for the help :0)
Not what you're looking for?
