Heating Mondeo Tddi
3 replies to this topic
#1 leslover
leslover
    Newbie
  • New Member
  • Pip
  • 6 posts
  • Ford Model: mondeo tddi mk3
Posted 27 November 2010 - 01:54 PM
hi, i have a problem with my heating, firstly the gauge in the car doesnt register when driving, only when sat still, and then it take ages to move, and secondly when driving the heaters are only ever warm, not hot, even after 30 mins driving, the expansion tank doesnt seem to hold much pressure either, it gets hot, but i can still unscrew cap and no steam etc...it doesnt use any oil or water, but i think mpg is down tho.....any ideas please?
Have something to contribute?
#2 gaz77
gaz77
    Member
  • New Member
  • PipPip
  • 14 posts
Posted 27 November 2010 - 03:28 PM
I think the best place to start is with the thermostat..... but they are not the cheapest thing from fords, sure mine was about 30 quid. If ya buy the houseing from fords you get the stat allready fitted inside and it only works out couple quid more for both.
Ps if ya only buy the stat carfull not to tighten up the bolts to much once the stat is in as they strip out the treads real easy.
#3 leslover
leslover
    Newbie
  • New Member
  • Pip
  • 6 posts
Posted 27 November 2010 - 08:41 PM
dnt suppose u know which 1 its likely to be dya? ive heard there is 2? is it more likely to be the oil cooler 1? ive been quoted 90+ for thermostat with housing or 15 just for the thermostat, im assuming there reasonably easy to strip down just to replace the stat and not the whole housing? also any instruction etc would be most helpful if u can please??
#4 gaz77
gaz77
    Member
  • New Member
  • PipPip
  • 14 posts
Posted 27 November 2010 - 09:05 PM
Yes there are two stats.... the oil cooler one is placed behind the water pump and is 15 quid from fords.
If ya confident enough to do your self start with the bigger one on the top right of engine and test with boiling water from kettle.
I would supose any garage will start with the one at top of engine. the oil cooler one is only small. and a little findly to get in.
I changed one myself and took me about hour, including replcacing coolant.
allways replace coolant with anti freeze....
check this link to another post....
http://www.fordowner...showtopic=16980
Not what you're looking for?
