Focus Fuel Gauge
6 replies to this topic
#1 Zetec Dave
Zetec Dave
    Member
  • PipPip
  • 10 posts
  • Ford Model: Focus Zetec 1.6
Posted 04 October 2008 - 02:55 PM
I bought a Focus Zetec 1.6 petrol (new model) from JCT600 in Leeds just over a month ago. As soon as I got the car I realised the fuel gauge was not working correctly, with readings showing all over the place. To cut a long story short JCT600 have just replaced the fuel sender unit (under warranty) but the problem is still there. I filled up yesterday and the gauge went immediately to full. Today however the gauge shows various readings from 1/4 to 3/4 full so it is clearly not working correctly.
JCT600 have been in touch with a Ford dealer who apparently told them that if replacing the fuel sender unit does not cure it then it is 'just part and parcel, and a characteristic' of that particular car. Needless to say that comment is incorrect and I have told them that I do not accept it.
Any suggestions as to what the problem may be would be very appreciated.
Thanks, David
#2 vinnyvangough
vinnyvangough
  • Super Mod
  • 2,225 posts
  • Name: Steve
  • Ford Model: Ford Escort RS2000 Mk6 & Mk2 Escort
  • Year: 1996
Posted 04 October 2008 - 10:01 PM
Could just be a poor connection on the wires.
I had this on my Escort and after a wiggle on the wires it is working fine now.
#3 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 04 October 2008 - 10:23 PM
its a common problem on the focus and is usually cured by a new sender unit.
#4 Zetec Dave
Zetec Dave
    Member
  • PipPip
  • 10 posts
Posted 05 October 2008 - 08:58 AM
But the sender unti has just been replaced. The problem is still there.
#5 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Year: 2006
Posted 05 October 2008 - 02:45 PM
i carnt understand why the gauge still plays up if they fitted a new unit because this problem is caused by a faulty fuel pump module which will have a poor / open circuit contact. A new revised fuel level sender card assembly should be fitted. and usually cures the fault all i can say is that the gauge itself must be faulty. these can be reset and i wouldnt accept the car with the gauge not working right would they recover you for free when you run out of petrol!
#6 Roger
Roger
    Newbie
  • Pip
  • 3 posts
  • Ford Model: zetec 1.6 focus
Posted 05 October 2008 - 07:00 PM
Whilst on this subject......
i have a 02 Zetec 1.6 Focus.
When i switch the engine off both the fuel and temperature gauges
bounce to the half or mid point.
When i start up they both return to the correct positions.
Is this normal or a similar problem ?
Cheers
Roger
#7 jr30864
jr30864
    Newbie
  • Pip
  • 9 posts
  • Ford Model: mondeo 1.8 td
Posted 05 October 2008 - 07:56 PM
Cheers
Roger
this seams to b the norm i drive mondeo friend drives focus and both the same
