Windscreen Washer
2 replies to this topic
#1 catriona1
catriona1
    Newbie
  • New Member
  • Pip
  • 3 posts
  • Ford Model: ford fiesta 1.4 tdci
Posted 05 December 2010 - 06:02 PM
hello, any help anyone can give me will be appreciated. I have a 2003 ford fiesta 1.4 tdci. the windscreen washers are not working, i have checked they are clean and the wash stuff is not frozen, the cables are fine. I no longer hear the whirr noise when i push the stalk and am assuming it is the pump. the windscreen wipers still work so it cant be the motor or fuse, i have checked the fuse box just in case but they look fine to me. however i am confused by some of the things i have read, some say motor some say pump but i think they mean the same thing. i have over used it recently due to the weather (16 inches of snow here!) all help appreciated. thanks very much
Have something to contribute?
#2 Stephen Leak
Stephen Leak
  • Budding Enthusiast
  • 100 posts
  • Ford Model: 2004 Fiesta Mk.6 1.4 TDCi Zetec
Posted 05 December 2010 - 08:57 PM
The motor and pump are a combined unit. The motor drives a little propeller which oves the water. They are usually located on the water reservoir (and therefore tricky to get at).
The fact that you can't hear the motor whirring makes me suspect that either the motor has burned out or the pump is simply clogged up, which is stopping the motor going around. The latter is more common.
It's maintenance by replacement, I'm afraid. And simple enough to do - once you get at it, though.
#3 artscot79
artscot79
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 7,927 posts
  • Name: arthur
  • Year: 2006
Posted 05 December 2010 - 10:54 PM
the washer fluid doesnt freeze the pump does so until the cars been driven and got really warm dont change anything best advice open the resevoir for the fluid and blow into it a few times any ice in the pump usually moves and then try it if still no joy youll need a new pump if its only happened since the cold weather suspect the pump is frozen
Not what you're looking for?
