jr30864 Posted October 5, 2008 Share Posted October 5, 2008 my mondeo if sitting high at the front ie on a hill only starts for a few sec then cuts out i then have to pump diesel back to the engine to start could it be a solenoid if so where is it located Quote Link to comment Share on other sites More sharing options...
mintalkin Posted October 5, 2008 Share Posted October 5, 2008 its most likely that you have a problem with air getting into the fuel line allowing fuel to drain back into the tank, check the sealing ring around the filter this is the most common area for this to hapen Quote Link to comment Share on other sites More sharing options...
jr30864 Posted October 5, 2008 Author Share Posted October 5, 2008 its most likely that you have a problem with air getting into the fuel line allowing fuel to drain back into the tank, check the sealing ring around the filter this is the most common area for this to hapen have already changed this part and still the same could it be one of the two pipes attached to it Quote Link to comment Share on other sites More sharing options...
jr30864 Posted October 13, 2008 Author Share Posted October 13, 2008 have already changed this part and still the same could it be one of the two pipes attached to it HELP Quote Link to comment Share on other sites More sharing options...
mintalkin Posted October 14, 2008 Share Posted October 14, 2008 have you checked the non return valve? Quote Link to comment Share on other sites More sharing options...
jr30864 Posted October 15, 2008 Author Share Posted October 15, 2008 have you checked the non return valve? no where is it and what does it look like Quote Link to comment Share on other sites More sharing options...
