Help With Dtc Codes
16 replies to this topic
#1 dougy.b
dougy.b
    Newbie
  • New Member
  • Pip
  • 4 posts
  • Ford Model: Focus Estate, 1.6 Zetec. 51 Plate
Posted 11 December 2010 - 03:54 PM
Hi all, Newbie here.
i've got a Focus 1.6 Zetec, 51 plate.
Ok, I'll start by mentioning that ever since i have owned the car (2 years now) i have had an issue with the speedo. on occasion it would stop working for a few seconds, then in winter it would do it more frequently and for longer periods. although it is a fault it has never really been a problem and has never turned the engine warning light on.
However, this morning i looked down to see that my speedo was up to it's old tricks again, only this time i had the engine warning light on as well.
So after reading this forum i found that i could do a self diagnostic by holding down the reset button on the speedo and turning the engine on.
I cycled through the tests and have got these DTC codes from it:
D123 Invalid or Missing Data for Odometer
D041 Invalid or Missing Data for Vehicle Speed
9318 Battery Voltage Low
I have also been told by a friend that it is possible that an issue with the alternator/low battery voltage could cause my speedo to do this.
so all in all these errors seem to hit the nail on the head, but as my speedo is now working again should the engine warning light have turned off or do i have to reset it. or possibly a new battery might help?
any help appreciated, thanks
Doug
Have something to contribute?
#2 dougy.b
dougy.b
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 11 December 2010 - 03:57 PM
Oh, i forgot to mention that when the speedo stops working the cars tends to kangaroo a bit in low gears, and the power drops (electric), I only noticed this because the volume of my stereo drops whenever the speedo fails, so that could explain the low battery voltage error.
#3 H3lly
H3lly
  • New Member
  • 282 posts
  • Name: k
  • Ford Model: Mk1 Focus
  • Year: 2003
Posted 11 December 2010 - 05:14 PM
It sounds like the speed sensor (located on gearbox) is at fault. The cylinder head temp sensor can cause this too. It's located between the spark plugs, and the cable causes interference when it comes in contact with the spark plug ht cables.
#4 dezwez
dezwez
    Dezwez
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 5,359 posts
  • Name: Derek
  • Ford Model: ford focus 1.8 zetec mk 2.5
Posted 11 December 2010 - 05:42 PM
i would say speed sensor happens a lot :)
#5 dougy.b
dougy.b
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 11 December 2010 - 06:22 PM
Thanks for the replies guy's,
would you say that the engine warning light should have gone out though? now that the speedo is working again (until next time :rolleyes: )
is replacing the speed sensor an easy job?
#6 H3lly
H3lly
  • New Member
  • 282 posts
  • Name: k
  • Year: 2003
Posted 11 December 2010 - 06:49 PM
Attached File  Engine How-to - Replace a VSS (Un-common type).pdf   512.42KB   902 downloads This should give you an idea of what is involved, see attached.
#7 artscot79
artscot79
  • PipPipPipPipPip
  • 7,995 posts
  • Name: arthur
  • Year: 2006
Posted 11 December 2010 - 07:31 PM
have to disagree on this one the stereo volume drops and you have a battery dtcv code ide be having the battery checked to see if it has a faulty cell therefore not charging correctly also check its a silver calcium or double calcium lead battery the ford smart charge has a sensor in it that can tell if a battery has double calcium or silver in the electrodes if it hasnt you can have all sorts of issues forget the vss and have the battery checked and tested for free in most garages if the battery is ok then go for the vss
#8 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,558 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 11 December 2010 - 11:34 PM
i would say vss
The reason the radio decreases is because the VSS sends a signal to the ECU which in turn sends a control signal to the radio's volume control circuit, the idea being the faster the car goes the more road noise etc; is generated so the radios volume is turned up to compensate, and vise-versa.
#9 dougy.b
dougy.b
    Newbie
  • New Member
  • Pip
  • 4 posts
Posted 12 December 2010 - 08:58 AM
i would say vss
But if it was the ECU controlling the volume then I wouldn't have got the low battery voltage error code would I?
I think i will probably check the battery first anyway, as that is definitely going to be the easier/cheaper option for me to sort.
but saying that i have always suspected the VSS anyway, so wouldn't be surprised if it is that.
thanks for the help everyone.
if anyone has any more suggestions they are more than welcome.
#10 matthew.bailey185
matthew.bailey185
    Newbie
  • Budding Enthusiast
  • Pip
  • 9 posts
  • Name: Matthew
  • Ford Model: Focus 1.6
  • Year: 2004
Posted 17 June 2014 - 08:04 PM
Hi doug , I have exactly the same issues . The car hunts at 2200rpm hence kangaroo in low gears . As regards the alternator , I tested the charge with and without the smart charge connected ..... With it connected the voltage would fluctuate 14.7 v no load , 14.3 v under load and disconnected maintains 13.8v .
I plugged in a alternator tester into the cigarette lighter , ikangerooing seems to reduce but for some reason after a period of time the alt voltage rises and the problems occur .... Did you have the same issue? .
Also is anybody aware of the earth/ neutral connection for the sensor and smart charge circuit in case it is an earthing issue ?
Cheers
#11 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,131 posts
  • Name: James
  • Year: 2007
Posted 17 June 2014 - 08:13 PM
The earth I believe is connected directly to the gearbox?
#12 nazsky786
nazsky786
  • 590 posts
  • Name: Naz
  • Ford Model: FOCUS MK2
  • Year: 2005
Posted 18 June 2014 - 08:18 PM
I say it might just be a faulty cluster. It's a issue that effects everything on the car. Engine going limp, cluster displaying nothing.
#13 matthew.bailey185
matthew.bailey185
    Newbie
  • Pip
  • 9 posts
  • Name: Matthew
  • Year: 2004
Posted 19 June 2014 - 05:06 PM
I changed the cluster today with a refurbished unit (The unit obliviously wasn't programmed with correct mileage etc..,). Symptoms were exactly the same.
Had an auto electrician look at it, as he had an IDS system, he assures me it is more than likely the target the sensor picks up in the gearbox..... umm as far as i'm aware there is no target as such, but what exactly does it pick up ??. I don't want to put in a refurbished box if we are barking up the wrong tree.
Also this does not explain the rise of mph when the car is revved stationary.
Any ideas ??
#14 nazsky786
nazsky786
  • 590 posts
  • Name: Naz
  • Year: 2005
Posted 19 June 2014 - 05:47 PM
Faulty sensor if it not the cluster then.
#15 matthew.bailey185
matthew.bailey185
    Newbie
  • Pip
  • 9 posts
  • Name: Matthew
  • Year: 2004
Posted 22 June 2014 - 08:56 PM
Things checked/changed so far:
-VSS sensor, changed with brand new ford genuine part.
-Cleaned existing cluster with contact cleaner
-Swapped cluster
-Parted every electrical plug/connector and cleaned, proven for continuity, S/C, E/F and high resistance.
-Tested alternator, found 13.8v with smart charge disconnected, with smart charge connected between 14.02-14.7V.
-Changed battery with approved CA type .
-Re-routed head temp sensor cabling away from HT leads and coil pack.
Can anyone tell me , what is else is part of the smart charge/VSS  circuit? . Is there a earth point ? .Also what does the sensor pickup in the gearbox?. Does the late 2004 Mk2 Focuses have Wheel speed sensors aswell as part of the ABS .
Cheers
Not what you're looking for?
