Hi.
( Ref... 02 plate. 1.6 Zetec Focus 47k.)
Some times on start up the cooling fans cut in and run, even on a cold engine.
They can stay on or cut out after a few miles.
My mobile mechanic hooked up his computer and there are no fault codes.
Any ideas as to the problem here please ?
All the best
Roger
Cooling Fans Run on start up.
Started by Roger, Oct 05 2008 07:07 PM
3 replies to this topic
#1
Posted 05 October 2008 - 07:07 PM
#2
Posted 06 October 2008 - 02:37 PM
is your air con switched on?
#3
Posted 06 October 2008 - 08:15 PM
No, but i know the problem now.
The cooling fans cut in when i put the blower on screen demist.
Switch it to footwell .... cooling fans goes off.
So i guess screen demist cuts in the AC ? (although the AC light does not come on.)
This is the norm i guess ?
Any thoughts welcomed.
Cheers
Roger
#4
Posted 07 October 2008 - 01:05 PM
yes the ac comes on with the screen demist button its quite normal, you can switch the ac off manually if you want once the screen button has been pressed.
