zev Posted December 12, 2010 Share Posted December 12, 2010 Hi all, the last couple weeks I've noticed fluid leak on my driveway at the front on the drivers side. I looked under the bonnet and couldn't see any leaks,the fluid dosent appear oily but light in colour and texture.I've been keeping an eye on all the fluids but the levels don't appear to be loseing. Any ideas guys. Zev Quote Link to comment Share on other sites More sharing options...
alz Posted December 12, 2010 Share Posted December 12, 2010 Hi Zev, you could have a leaking water pump, as you say its not oily, keep an eye on the water, also have you been using the aircon as the condensed water from the aircon can stay on the under sheild and drip off on to the floor . Quote Link to comment Share on other sites More sharing options...
artscot79 Posted December 12, 2010 Share Posted December 12, 2010 Hi Zev, you could have a leaking water pump, as you say its not oily, keep an eye on the water, also have you been using the aircon as the condensed water from the aircon can stay on the under sheild and drip off on to the floor . run youre finger under the power steering pump leaks at the pipe right under the pump or check the sump Quote Link to comment Share on other sites More sharing options...
zev Posted December 12, 2010 Author Share Posted December 12, 2010 Thanks will have a look tomorrow. I've only been using the heaters. Zev Quote Link to comment Share on other sites More sharing options...
