Part Of Dial Not Lighting Up
5 replies to this topic
#1 cressws1
cressws1
  • New Member
  • 252 posts
  • Name: Scott
  • Ford Model: Focus Zetec 1.8
  • Year: 1999
Posted 23 December 2010 - 04:45 PM
Please see the picture, The section highlighted that displays the mileages etc doesn't light up anymore, It does show the relevant information and is clearly visible in daylight, But the green "glow" the surrounds the rest of the dash doesn't occur here. Ive checked that the connection into the rear of the unit is secure. My question is is there simply a bulb that unscrews etc from the rear? I remember removing a small bulb for the "tailgate open" warning light but can't remember if its the same for this section of the unit.
Any help appreciated as usual.
Have something to contribute?
#2 H3lly
H3lly
  • New Member
  • 282 posts
  • Name: k
  • Ford Model: Mk1 Focus
  • Year: 2003
Posted 24 December 2010 - 01:38 AM
It's a screw in bulb. I've never had to remove it 'touch wood'. On the mk1.5 it's an smd and would require soldiering.
#3 cressws1
cressws1
  • New Member
  • 252 posts
  • Name: Scott
  • Year: 1999
Posted 25 December 2010 - 07:06 PM
Cheers mate, Found its whereabouts this morning, Seems simple enough. Does anyone know where I can get a replacement bulb from or does it have to be Ford?
#4 H3lly
H3lly
  • New Member
  • 282 posts
  • Name: k
  • Year: 2003
Posted 25 December 2010 - 07:22 PM
Here is the 'how to' guide on removing the old bulb: http://www.focushack...ulb replacement I don't know the name of the bulb, but call into ford an they will will sort it.
#5 johnH
johnH
  • 1,136 posts
  • Name: John
  • Ford Model: Focus mk2 Zetec 1.8 TDCI (Climate)
  • Year: 2006
Posted 26 December 2010 - 08:01 AM
if i am looking at that correctly you could "upgrade" those bulbs to LEDs called 509/t or 509 twists.
upgrading these will stop "burnout" over time and save you the hassle, if all changed at same time, of removing the cluster to replace them.
if they need to be green bulbs.
http://www.crazyleds...-509T-LED..html
or if they are white:
also with those you wont get "hotspots" as the top is flattened out so it spreads the light
just a thought i'd share with everyone.
#6 cressws1
cressws1
  • New Member
  • 252 posts
  • Name: Scott
  • Year: 1999
Posted 13 January 2011 - 09:08 PM
Sorted this today. Got the bulb in its little grey socket for 2.40 from FORD. Took 10 minutes to replace and the links above were really helpful.
Thanks to all who helped.
Not what you're looking for?
