Mk2 Focus Instrument Cluster
4 replies to this topic
#1 Geoffrow
  • New Member
  • Pip
  • 7 posts
  • Ford Model: Focus sport
Posted 02 January 2011 - 07:53 PM
I need some help as my car has been playing up over the last 3 months with a red cog and the caution light keeps coming on. I lose power to the car when driving it is like changing from 2nd gear to 5th gear. My car has been to two diffent garages the first garage said it was the instrument cluster and told me that only Ford can replace it. So off I sent my car (Focus 1.6 Sport) to Ford and spent 160 on dianogstics and a repair to the plugs on the passenger side they said that if it happen again that they will need to rewire my wiring loom. Took the car home and the next day the red cog and the caution light came back on. I took my car back and they said thay will need to re wire the plugs. This took them over 2 weeks until i got the car back and cost me another 105 and then 2 weeks later the red cog and the caution light came back on. I have been back to ford and now they THINK it is the ABS moduel.
Has anyone had this problem because I don't think it is the ABS moduel as when I tap the dash six warning lights come on, Oil light, battery light, red cog and the caution light, ABS light, Hand brake light and the engiene management and my immobiliser flashes.
Have something to contribute?
#2 jeebowhite
    Resident Loon
  • Super Mod
  • 21,740 posts
  • Name: James
  • Year: 2007
Posted 03 January 2011 - 10:29 PM
it could be anything from a loose wire, to a short circuit, or it could be coincidence and there could be the issue with the modules / relays etc, either way sounds electric. Not sure really what you can do other than trust Ford, or take it to an auto electrician.
#3 Gazw
  • New Member
  • Pip
  • 1 posts
  • Name: Gary
  • Ford Model: Focus 1.6 LX
  • Year: 2006
Posted 19 October 2013 - 06:52 PM
Hi Geoff,
just found this post searching google and I have the exact same issue with my focus ( 55 plate ).  I have come across quite a lot of similar problems with other focus owners but your thread is the first of an exact match.  Would you be able to say exacly what sorted the issue as I would rather have a go myself before spending hundreds on labour alone and possibly weeks without a car.  So far I have removed the instrument cluster and cleaned the printed circuit board like some sites suggested. While refitting the cluster I noticed the lights going mad when i lightly touched the wiring loom that connects to the cluster ( via a connector ).  I was wandering if you could confirm if any of this sounds familiar with you and if your cluster issue is now history???
Kind regards
#4 JW1982
  • True Ford Enthusiast
  • 911 posts
  • Name: Wilco
  • Ford Model: Focus MK3 Champions Edition
  • Year: 2013
Posted 20 October 2013 - 06:50 AM
This is a known problem of the Focus MK2/MK2.5 instrument cluster. The problem is caused by bad soldering connections of the connector to the circuit board. The soldering connections become cracked due to vibrations. This results in an open connection of 1 or more pins of the connector.
Many times the problem can be solved by resoldering all 32 pins of the connector to the circuit board. You just have to disassemble the instrument cluster to remove the circuit board. Now you can heaten up every soldering connection of the connector with a soldering iron with a small tip. I repaired several MK2/MK2.5 instrument clusters this way. In my opinion it is definitely worth a try.
#5 Focuz
  • Budding Enthusiast
  • 62 posts
  • Name: Lewis
  • Ford Model: Focus LX
  • Year: 2006
Posted 21 October 2013 - 12:22 PM
I had this problem before, but a local garage recommended a company to me which cleans up and repairs the circuit board and gives a 2 year warranty for about £100, saved me paying out around £700 for a new cluster!
Not what you're looking for?
