mack2 Posted January 2, 2011 Share Posted January 2, 2011 Hi, When I started the car the other day my Galaxy came out with an audible beep and a yellow warning light came on on the central dashboard light cluster. I do not have a manual for my MKII 1.9TDi (nor can I find a manual that covers this 2002 model - does it exist?). The warning light is a circle with two dashed line part the way around the outside of either side of the circle. Have attached a couple of images showing the light and its position on the dashboard cluster. It isn't the ABS light(yellow) or the Handbrake light(Red). Can anyone help? Cheers, Mack2 Quote Link to comment Share on other sites More sharing options...
mack2 Posted January 2, 2011 Author Share Posted January 2, 2011 OK, so I did a bit of further surfing and have discovered this is a universal symbol for brake pad warning indicator. First timer I have had a car with this on it so will now try and work out which pads are affected. If anyone has access to an up to date manual I would like to know what edition it is as the one that came with my car is for a MKI which is of no use to me :-( Quote Link to comment Share on other sites More sharing options...
Quigley Posted March 17, 2011 Share Posted March 17, 2011 OK, so I did a bit of further surfing and have discovered this is a universal symbol for brake pad warning indicator. First timer I have had a car with this on it so will now try and work out which pads are affected. If anyone has access to an up to date manual I would like to know what edition it is as the one that came with my car is for a MKI which is of no use to me :-( Hi Mack2 I have the same problem with my newly acquired 1.9 TDi, 2004 model and I am lookign to buy a Handbook on eBay. Did you manage to solve the problem in the end? (I initially thought it was the ABS light!) Cheers Quote Link to comment Share on other sites More sharing options...
Growler Posted December 13, 2014 Share Posted December 13, 2014 Defo the Low Brake Pad Waring Light. Either Pads are low as they will have a metal strap or faulty wiring. I believe if ABS Warning shows ABS Letters in yellow Quote Link to comment Share on other sites More sharing options...
