Support the club!
No Hot Air
5 replies to this topic
#1 jwb
jwb
    Newbie
  • Pip
  • 1 posts
  • Ford Model: puma 1.7
Posted 04 January 2011 - 11:20 PM
CAN ANYBODY HELP WENT TO USE CAR TODAY DROVE FOR ABOUT 10 MINS SWITCHED HEATER ON AND NO HOT AIR ONLY COLD COMES OUT ANY SUGGESTIONS.[/size][/size]
#2 taffg
taffg
  • 503 posts
  • Ford Model: focus 2.0 zetec Mk 1
Posted 05 January 2011 - 10:34 PM
the thermostat may be stuck open, not allowing the engine coolant to warm up. is the engine temperature gauge reading normal.
#3 btmaldon
btmaldon
  • PipPipPipPipPip
  • 1,589 posts
  • Name: Bruce
  • Ford Model: Focus Sport
  • Year: 2011
Posted 16 January 2011 - 05:28 PM
Probably the Heater Control Valve is stuck open or the Heater Control Panel fitted to the back of the heater control knob, needs replacing. Start with the HCV valve as these are a really common prblem.
#4 mart2710
mart2710
    Newbie
  • Pip
  • 7 posts
  • Ford Model: Ford Focus 2.0 Ghia
Posted 21 January 2011 - 10:02 AM
^^^ This just done the heater valve on my daughters Ka not too expensive either ....easiest way to check is heater valve is located on bulkhead ...check pipe going in and pipe coming out ..if pipe is hot going in and cold the other side then it is the Valve
#5 Jbizzle
Jbizzle
    Newbie
  • Pip
  • 5 posts
  • Ford Model: puma
Posted 21 October 2012 - 08:46 AM
how much was it to replace then mate.? is it the same for a PUMA.?
#6 btmaldon
btmaldon
  • PipPipPipPipPip
  • 1,589 posts
  • Name: Bruce
  • Year: 2011
Posted 21 October 2012 - 02:24 PM
Puma, Fiesta and KA all use the same part. Less than £40 from Fords.
