FAN BLOWERS NOT WORKING
6 replies to this topic
#1 slingmaker
slingmaker
    Newbie
  • Pip
  • 3 posts
  • Ford Model: TD ESTATE
Posted 10 October 2008 - 11:38 AM
Hi guys
The blowers in my focus only work on level 4 , ive been intouch with a local mechanic and he said he can sort it for £50 . He said i need a resistor unit . If so are these easy to fit ? as i would do it myself . Any ideas on what else it could be ?
Cheers
#2 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 10 October 2008 - 01:01 PM
its most likly the resistor pack which is located behind the glovebox and held in place by an 8mm bolt, but it could also be the dash switch. 9 out of 10 times its the resistor pack
#3 slingmaker
slingmaker
    Newbie
  • Pip
  • 3 posts
Posted 10 October 2008 - 01:22 PM
Where can i pick one of these up and are they easy to fit ??? a local mechanic said hed do it for £50 supplied and fitted but i cant really affoRd to pay that .
Cheers for your help
#4 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Year: 2006
Posted 11 October 2008 - 05:04 PM
give these guys a ring and find the price of the resistor pack
http://www.fordpartsuk.com/
#5 Mattie
Mattie
    Newbie
  • Pip
  • 9 posts
  • Ford Model: 2006 Ford Focus 1.6tdci
Posted 14 October 2008 - 07:18 PM
Hello mate, i had the exact same problem with my 96 fiesta, what had caused it was the multiplug behind the glovebox had burnt out, so i cut the plug off and attached spades to the end of the wiring and connected them manually and now it works like a dream and it took me bout 10 minutes and cost me 7.99 for a big spade wiring kit but really all yu need is 4 fittings which will cost bout 50p hope this helps
#6 Chris413
Chris413
    Newbie
  • Pip
  • 1 posts
  • Ford Model: Puma 1.7
Posted 14 April 2010 - 04:17 PM
Is the resistor pack in the same place on a Ford Puma? I have already replaced the HCV and the speed switch and still no blower.
#7 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,321 posts
  • Name: mintalkin
  • Year: 2006
Posted 15 April 2010 - 03:30 PM
yes i think it is,if you puma was built before 10/1999 The problem may be caused by a poor electrical contact of the blower motor resistor multiplug. The high current passing through the resistor may be the cause of the melting multiplug. The solution is to fit a new blower motor resistor that has modified connectors that can withstand the high temperatures along with a new wiring loom to the resistor.
