Help Me Plz
1 reply to this topic
#1 l3onxr
  • New Member
  • Pip
  • 2 posts
  • Ford Model: escort van
Posted 16 January 2011 - 05:00 PM
hi all iv brought a 2002 escort van 1.8 diesel 55 ian im having trouble with it it is strugling to start so i changed glow plugs fuel filter and air filter but has made no diferance at all can any 1 plz help me
Have something to contribute?
#2 lublin
  • Budding Enthusiast
  • 101 posts
  • Ford Model: Escort Estate 1.6 16v . Built 14/11/95.
Posted 17 January 2011 - 05:28 PM
If it were mine I would: use injector cleaner,
look for damp areas (diesel) along the fuel lines near the pump/injectors because fuel out = air in and you might be pumping the air through after it's been stopped a while,
also have the nuts on the pump been spannered i.e. has someone altered the pump timing or been messing with things,
does it smoke whilst driving indicating either burning oil (worn engine) or worn injectors,
how does it run as, if the valve clearances have gone tight it will have reduced compression and so poor starting and running,
does it turnover fast enough or is there a problem with this (could be a few things)?
Not what you're looking for?
