lucas1787 Posted January 25, 2011 Share Posted January 25, 2011 Hi, All my doors will unlock using the remote, but if I use the key in the drivers door it only opens that door.Is this a door lock fault in the drivers door or something else????. Thanks Dave Car is Focus 1.6 Zetec 1999 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 25, 2011 Share Posted January 25, 2011 Sounds like it could be a wiring issue, when you use the fob, it is picked up by the transciever and activates the locks from somewhere under the bonnet, when you use the key in the door, it travels through the door and to the rest of the car. I *think* that they are on two seperate wiring setups... Quote Link to comment Share on other sites More sharing options...
lucas1787 Posted January 25, 2011 Author Share Posted January 25, 2011 Sounds like it could be a wiring issue, when you use the fob, it is picked up by the transciever and activates the locks from somewhere under the bonnet, when you use the key in the door, it travels through the door and to the rest of the car. I *think* that they are on two seperate wiring setups... Do you think it could be the loom running through the door/pillar or where the lock is.?Is there a common place that they go?.Thanks Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 25, 2011 Share Posted January 25, 2011 Could be the loom, but I'm by no means the best to ask on wiring I'm afraid. The pillar sounds about right, but I would jog around google for a while, someone somewhere will have something, take a look out at other ford forums, as they have a lot of useful information! Does the central locking activate if you unlock the passenger side door? I know predominiantly it only works on the Drivers side, but some cars will work either side. Quote Link to comment Share on other sites More sharing options...
lucas1787 Posted January 25, 2011 Author Share Posted January 25, 2011 Could be the loom, but I'm by no means the best to ask on wiring I'm afraid. The pillar sounds about right, but I would jog around google for a while, someone somewhere will have something, take a look out at other ford forums, as they have a lot of useful information! Does the central locking activate if you unlock the passenger side door? I know predominiantly it only works on the Drivers side, but some cars will work either side. Yes it does work using the key in the passenger door, so which tends to point youre theory of it being a wiring problem at the drivers door.I will have a look at the wkend when I have time,light and hopefully good weather.Thanks for the advice. Quote Link to comment Share on other sites More sharing options...
Apex Posted January 26, 2011 Share Posted January 26, 2011 This might be of help :) Quote Link to comment Share on other sites More sharing options...
lucas1787 Posted January 26, 2011 Author Share Posted January 26, 2011 This might be of help :) Thanks Apex, I will give that a go first with the WD40 trick, before attempting to remove the door panel. Cheers :) Quote Link to comment Share on other sites More sharing options...
kgberry Posted January 27, 2011 Share Posted January 27, 2011 Hi, All my doors will unlock using the remote, but if I use the key in the drivers door it only opens that door.Is this a door lock fault in the drivers door or something else????. Thanks Dave Car is Focus 1.6 Zetec 1999 Quote Link to comment Share on other sites More sharing options...
lucas1787 Posted February 1, 2011 Author Share Posted February 1, 2011 Update. I took out the bottom screw holding the door lock and sprayed WD40 in through using a small tube attached and hey presto the door now locks using the key,BUT the interior light wont go out when its locked???Any ideas on this. Thanks again Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 2, 2011 Share Posted February 2, 2011 (just to cover the obvious!) you havent got the interior light set to permenant on have you? make sure it sits in the middle, and if its sat pointing to your driver window... pretend it wasnt! Otherwise, sounds like its still a wiring issue. my belief is that the loom that runs along all doors, closes a circuit when the car is locked, on closing the locking circuit and locking all doors, I think it opens the interior light circuit, it could be that there is a link somewhere that is preventing it from opening the circuit properly. Does the light go out when you close the doors from the inside? or does it only go out when you start the engine? Quote Link to comment Share on other sites More sharing options...
lucas1787 Posted February 2, 2011 Author Share Posted February 2, 2011 (just to cover the obvious!) you havent got the interior light set to permenant on have you? make sure it sits in the middle, and if its sat pointing to your driver window... pretend it wasnt! Otherwise, sounds like its still a wiring issue. my belief is that the loom that runs along all doors, closes a circuit when the car is locked, on closing the locking circuit and locking all doors, I think it opens the interior light circuit, it could be that there is a link somewhere that is preventing it from opening the circuit properly. Does the light go out when you close the doors from the inside? or does it only go out when you start the engine? If I use the remote to lock,the light does go out,its only when I use the key it stays on,so as you say there still must be a wiring issue in the door/lock assy.I was hoping not to take the door panel off,but looks like I might have to but will have to wait until the weather gets warmer as I dont have a garage.The other good thing is,the locks now dont try to re-open again when I am driving,so spraying WD40 in the lock must of done something.! Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 2, 2011 Share Posted February 2, 2011 Good Job, hopefully it works out! Quote Link to comment Share on other sites More sharing options...
