Pollen Filter
#1
Posted 29 January 2011 - 01:00 PM
#2
Posted 29 January 2011 - 02:47 PM
Regards Brian
#3
Posted 29 January 2011 - 03:19 PM
1) remove glove box
2) drop fusebox from bracket (no need to disconnect the wires)
3) remove fusebox bracket
4) you will see a black long shaped plastic cover, remove 3 bolts
5) remove old, insert new
6) reverse instructions to reassemble
right pain in the !Removed! first time, but i noticed a difference straight away, fresher air etc
#4
Posted 29 January 2011 - 08:07 PM
#5
Posted 29 January 2011 - 08:15 PM
Pasanger side foot well, remove glove box, remove fuse box, filter is located to right of fuse box behind a oblong shaped cover held by 3 or 4 screws, first time you think never again, but each time it is renewed it seems easier, dont be put off, it dose require changing, I do mine every 20,000.
Regards Brian
#6
Posted 30 January 2011 - 08:45 AM
eurocarparts have loads of variety and even a visit to unipart, andrew page or any other motorfactor will be able to get them cheaper than halfrauds. i paid £5 for mine at Darlington Kar Parts. halfords will most likely want around £10-£20.
i bet its the same range of filters across the whole mk2 range. could be wrong tho.
#7
Posted 31 January 2011 - 12:18 PM
Yes I thought that John, the Ford one, part no. 1 494 691 looked like favourite. Anyway I saw one on Ebay, but it said for 2006 onwards, so I contacted the guy. He asked for my reg [55 plate] then came back to me saying it was an earlier one. He said he works for Ford and checked it on the Ford data base, so he said order the one on Ebay, but he will send the correct one for my car. [£5.64 delivered]
So I suspect it will be like the one advertised, a Ford replacement filter. Either way when it arrives, I'll post back on here what part no it is.
#8
Posted 05 February 2011 - 04:27 PM
The filter has arrive and it is as I suspected the Ford supplied one, part number: 1 494 691. Like you John I could not see there being different filters for the same model, be it a 55 plate or a 06 plate.
Edited: 6th Feb 13:10.
The physical dimensions are 230mm x 210mm. Now I have not tried replacing it yet as the weather is crap. But when I do, I'll be able to report back here wither it fits or not. Of course anybody having replaced one wither it be a genuine Ford offering or not, should be able to confirm if it conforms to the right dimensions.
Knowing if it is the correct part number means you can stand a good chance of picking one up on Ebay for a couple of quid plus postage. I say that because there seems to be a lot kicking about on Ebay on 99p start auctions. Possibly garages buy in service kit's, but mechanics don't actually change the pollen filters, simply because its an @rse of a job. And come on how many punters if any would take out the old one. [to see how dirty a used one looked like] and then do the same again to check if it had indeed been changed. So subsequently they end up on Ebay [guy I bought mine off said he worked for Ford]
Call me a cynic if you must, but it comes with age. In that the primary objective of any and all business is to take as much money out of your pocket, whilst employing as little effort on their part as possible.
#9
Posted 06 February 2011 - 08:33 AM
this part will most likely fit the entire mk2 range and i bet other models say the mondeo etc, from what i have learnt is car manufacturers save loads of money by doing this so most have adopted this method...worst i have seen for this is peugeot (hence all their problems).
#10
Posted 09 February 2011 - 11:00 AM
The question you have to ask yourself is this...has it ever been changed?
Lets look at my motor as an example.
It's a 55 plate, so at the time I write this post, it is five years and four months old. Having supposedly undergone four services prior to coming into my ownership back in October 2009. It had what was agreed prior to me picking it up from the selling Ford Main dealer, a 37.5K major service. It was sold as a "Franchise Approved Vehicle" Now I was present when my mechanic did it's first service in my ownership in October 2010, and I said I would do the pollen filter myself at a later date. Now bare in mind the pollen filter is supposed to be changed at every annual service. Myself I think that is not really necessary unless your doing a fair mileage say 20K or above.
Anyway my motor has 39,396 miles on the clock, and when I removed the filter I Googled the manufactures name, Micronair you will see on that page that it states:The majority of all new vehicles are fitted with micronAir.
So, given that the Ford replacement pollen filters part number 1 494 691, the one I fitted, are slightly different to the Micronair one I removed. And given that there are quite a few different after market branded filters stocked by auto parts suppliers to the trade. It would be fair to assume that the filter I removed was in fact the original filter installed in the aircon unit prior to it being installed at the time of the cars build date. Indeed the nut headed type screws that secured the filter cover, looked like they had never seen a socket since the day they were originally screwed in.
So I would recommend to all that if you want to be sure your motors filter is up to the job, best to replace the filter yourself. Like I said on my last post Ebay is full of auctions of these filters
Additional Tip:
Photo one shows the glove box removed, now after removing the glove box, 4 screws at top, 3 at the bottom. Disconnect the mechanism that is supposed to stop the glove box door from opening to quickly. It's just to the right of the opening in the picture, a plastic rod in a cylinder type thing. Then just pull the glove box lid [using both hands] it will come away from it's securing hinges. Reverse instruction to refit, you will hear it click into its hinges.
#11
Posted 10 July 2011 - 07:24 PM
On my old Picasso, lift bonnet, undo 3 wing nuts at back of engine, remove plate ,replace filter. Job done in less than 2 mins flat.
When replacing the light bulbs for the Focus, let me guess, another hour and a half needed for that no doubt? Ha Ha. What a joke.
#12
Posted 10 July 2011 - 08:48 PM
the headlight thing is a bit of a joke but no more than 2 mins, 1 torx screw, pull light out...gain access to light unit...no need to disconnect electrical connection...
i see where your coming from but if you want worse you should look at a peugeot...to replace headlight bulb you have to dismantle the accelerator cable unit. the pollen filters on those aswell, you need to be the hulk to get the protector panel off...and when you do you have to go buy new from peugeot for £30!!! on order aswell!
#13
Posted 10 July 2011 - 09:37 PM
nout to hardly complain about really...7 torx screws and your glovebox can pull out...easy.
ive never needed to remove the headlight its pretty doable ide say takes a minute to do both
#14
Posted 10 July 2011 - 10:02 PM
You see peeps that's the beauty of running a Ford, you can pick up a genuine Ford replacement filter for less than £6 on Ebay.
Was watching Top Gear tonight, loved the piece about buying second hand "dogs bollacks" motors for less than 6K.
James May was right, and I would say that people earning average earnings or less would probably soon find out why motors like that are only 6k to buy. And as May said it would probably bankrupt anybody buying them, V12 petrol mmmmmmmmmm nice, just think of the fuel , insurance, road tax, and servicing costs. Then when something needs replacing ............
#15
Posted 10 July 2011 - 10:12 PM
on the mk2 focus you need to remove the headlight to change a bulb..
Latest Comments
More
