Poor Starting
5 replies to this topic
#1 al & cat wilson
al & cat wilson
    Newbie
  • New Member
  • Pip
  • 7 posts
  • Ford Model: Mondeo tdci Ghia X (130)
Posted 31 January 2011 - 05:25 PM
Hi all.
We are Alec and Catherine, we had a Mondeo 2.0 tdci about 3 year ago and desided to get a landrover freelander to pull our caravan better as it been a 4x4 ( what a mistake ) so now we have managed to get ourselves a fantasic Mondeo 2.0 (130) ghia x in black and we love it.
The only problem we have is somtimes when we start the car it will start then stall after a second or two somtimes it will take 2 or 3 attempts to start correctly or it will start but sound like a bag a hammers the revs will not lift any more than about 500 rpm then rise to normal speed after a few seconds and the engine runs fine .
Can any one shed any light on this problem ? advice much appreciated .
Thanks Alec .
Have something to contribute?
#2 MoneyHead
MoneyHead
    Newbie
  • New Member
  • Pip
  • 1 posts
  • Ford Model: Mondeo 2.0 TDCi 130 Ghia X
Posted 05 February 2011 - 09:31 AM
Hi Alec, I have the very same car TDCi 130 Ghia X in black! having the same problem, mine starts fine from cold but if you start when warm it takes up to four trys then starts but like yours the revs stay at 500 rpm and the ECU light for a few seconds and then clears and the revs are fine again. Does your ECU light come on as well? I have been told by a garage that it is the EGR valve causing the problem, I will let you know if it fixes the problem when I have it replaced.
#3 taffg
taffg
  • New Member
  • 503 posts
  • Ford Model: focus 2.0 zetec Mk 1
Posted 05 February 2011 - 10:33 PM
you may want to search the forums as someone posted an egr valve strip and repair with photos and saved a small fortune,but i cant locate it!
#4 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,543 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 06 February 2011 - 02:22 PM
bad statring from warm on the tdci is a well known problem and there is a pmc update from ford to cure it.if you want to clean the egr valve see here.
http://www.fordwiki.co.uk/index.php?title=EGR_Valve_and_Inlet_Manifold_Clearout_TDCi
#5 al & cat wilson
al & cat wilson
    Newbie
  • New Member
  • Pip
  • 7 posts
Posted 06 February 2011 - 09:55 PM
Thanks guys your advice seems invaluble next weekend you will find me in garage head under the bonnet spanners in hand wish me luck ;)EGR valve here i come
#6 al & cat wilson
al & cat wilson
    Newbie
  • New Member
  • Pip
  • 7 posts
Posted 06 February 2011 - 10:01 PM
Hi moneyhead ,
What a car we love it . check out the other posts sound not to hard and could save us some money ?
where you at in the uk ?
Not what you're looking for?
