Fix Durashift Gearbox Problem Easy.
39 replies to this topic
#1 lasse1955
lasse1955
    Newbie
  • Pip
  • 8 posts
  • Ford Model: fusion 03
Posted 01 February 2011 - 08:33 PM
(Sorry for some bad English language in this….)
The durashift on my Fusion has malfunctioned sometimes the last month.
No reverse sometimes, no forward gears other times, gears get stuck and at last no gear at all (but the display showed “4”).. Always with the sprocket warning-light lit.
Ford workshop wants 1000£ to fix it, at least.
But the solution was simple, if you are normally handy and can spare an evening.
Everyone think durashift is complicated, complicated and more complicated, BUT THIS IS NO ROCKET SIENCE!!
The problem was the shift actuator (see picture 1).
The shaft from the gearbox that is connected to the actuator was stuck. It should be possible to turn and pull, if normal.
So I disconnected the gearbox shaft from the actuator (one screw), and discovered that the gearbox shaft then was possible to turn, but the actuator was stuck (motor no 1. The one with the white plastic ball joint).
I connected 12v to the actuator motor (motor 1. Pin 1 and 6) but the motor was only "humming". It was really stuck.
I removed the actuator from the gearbox (4 screws). Then I removed the actuator motor no.1 (four screws, se picture 2.) but the actuator was still stuck. It was not possible to push and pull the slider (that now should be really easy to move, as the motor now was gone).
I took a big screwdriver and bent it loose, and discovered then that the rack was stuck in its plastic slide surface (I don’t know the correct English word) inside the actuator housing.
The plastic was a just little deformed but enough to get the rack to stuck really hard.
I drilled a hole in the closed end of the “plastic slide surface” (se picture 3.) and then a bigger hole (see picture 4) to see well and to be able to put in some tool.
Now I saw a little “bump” in the plastic surface (and some dirt). I took a 16mm reamer to make the plastic surface smooth (picture 4.). Now the rack was sliding nice and easy.
If you can’t borrow a 16mm reamer you sure can use a sharp knife or a file or a Dremel or something similar.
I put a plastic cap over the drilled hole and glued it (picture 5).
I mounted the actuator, and the gearbox is working as new.
It feels so good!
Cost? Nothing!
Some tips: DON’T turn the motor when you have removed it from the actuator!!!!! It has position sensors in it, and needs to match the position of the rack!!
Make a mark on the rack before you bend it lose, it must match the position of the motor when you mount them together.
I am not really sure what causes this, but plastic deformation over time is nothing new.
But more likely I think the problem is water. As the plastic slide tube is pointing upwards I guess a small amount of water have come between the plastic tube and the aluminum housing. Either has it there frozen to ice and therefore expanded to a “bump” in the plastic, but more likely it has there caused corrosion on the aluminum which expands to a “bump” inside the plastic tube.
As I glued the cap I assume no more water can enter, to cause more problems.
Greetings from Sweden.
  • Attached File  1.jpg   88.02K   1887 downloads
  • Attached File  2.jpg   143.97K   2269 downloads
  • Attached File  3.jpg   103.2K   2205 downloads
  • Attached File  4.jpg   113.14K   2055 downloads
  • Attached File  5.jpg   171.11K   1987 downloads
  • Attached File  6.jpg   115.49K   1542 downloads
#2 Dan62
Dan62
  • 236 posts
  • Ford Model: Fiesta
Posted 07 February 2011 - 11:21 AM
Great post, thanks for sharing this and great you have included pictures.
Do you think there is any preventative or maintenance work that could be done to the actuator assembly ?
I am thinking about major servicing of my car, cam belt, gearbox oil change, coolant and brake fluid change etc, have you any thoughts on bleeding the clutch actuator assembly ? There is a part of me thinking if its working leave it alone !!
D
#3 lasse1955
lasse1955
    Newbie
  • Pip
  • 8 posts
Posted 07 February 2011 - 06:33 PM
Yes, to prevent water (with road salt) to penetrate the space between the plastic bush and the aluminum housing you can seal this space with some elastic mass.
I sealed mine with glue, as I glued the plastic cap at the end of the bush.
Only glue, or something similar, should be enough in your case (clean area first).
I have got information by "Meikel_K" that this problem has been notified, so that later actuator parts, and spare parts, have a similar modification.
#4 Dan62
Dan62
  • 236 posts
Posted 16 February 2011 - 02:41 PM
Lasse, you are a star and have just saved me lots of £'s and much grief.
Today I changed the gearbox oil so I had to remove the actuator assembly to access the filler / level plug.
I only intended to put some sealant over the top of the white plastic bush while the actuator was out, however, since I had the assembly in my hands I decided to remove the motor and check how stiff the shaft was... It was almost seized and I had to lever it with a screwdriver to get it to move.
I popped the ball joint from the shaft to the lever and removed the shaft, I then used a small blade to scrape around the inside of the bush reinserting the the shaft until it moved fairly easily.
I didn't have a 16mm reamer, it may have made the job a lot easier but possibly the lever attached to the assembly would stop you from inserting it from underneath anyway (I didn't want to drill the bush out from the top).
Thanks again for taking the time to post this information, it was a simple job and has hopefully extended the life of the assembly, the motor must have been straining to move that shaft up and down each gear change.
D.
#5 lasse1955
lasse1955
    Newbie
  • Pip
  • 8 posts
Posted 16 February 2011 - 09:19 PM
Thank you for your encouraging words.
I am glad you could make use of my experience.
It is always nice to be able to help somebody.
Lasse
#6 GAZZ..A
GAZZ..A
    Newbie
  • Pip
  • 1 posts
  • Ford Model: Fusion
Posted 17 February 2011 - 07:06 PM
Hi lasse my 53 plate fusion in in the ford shop now and are saying £403.61 for a new actuator, i have the same problems as you,lose of gears , reading 4 ect ..I am handy with the tools and am thinking should i pay to get the job done.or take it out the shop and have a go at this Gary..Thay will fit it free as have i already paid for software update that thay said it would fix gear problems..but 50 feet down the road and it did it agine ,reading 2 but light came on and no driveNICE POST MATE ,,GOT ME THINKING
#7 Dan62
Dan62
  • 236 posts
Posted 18 February 2011 - 10:16 AM
Gazz, you've got nothing to loose doing it yourself. It doesn't require any special tools other than maybe a 16mm reamer or similar to open out the plastic bush.
A total of 6 screws and 2 connectors to remove the actuator and 4 screws to remove the motor. Just note Lasse's tip about marking the shaft position to reassemble it in the same position. Oh, don't panic when the gear falls out of the motor !
I raised the front of the car a few inches to make access easier and with draining / changing the oil and general pratting around it took just over 2 hours.
Finally, I didn't appreciate how much of an improvement the job had made until yesterday when I done my daily commute, the gearchange is smoother and especially no more harsh downshifting notably into 2nd and 1st which is the reason I intended changing the oil for SMX_S but it may have been down to the actuator... Who knows but it definitely a great fix and would go so far as to recommend anyone with this gearbox, especially around this age to get this done before it starts playing up.
Good luck, D.
#8 koslanski
koslanski
    Newbie
  • Pip
  • 2 posts
  • Ford Model: fiesta
Posted 17 March 2011 - 03:42 PM
Hi guys, I have similar problem as above with fiesta durashift automatic, it does not start at the moment, the gears seemed to be changing ok when it was driving, but it had moments when it would not start, then after some time it starts and drives well until next time. A couple of days ago it started ok, took off with the first gear but then it was only reving but not pulling. I had to tow it home and after coming across this forum decided to do the same adjustment to shift actuator as described in the above posts. I thought that would solve my problem, but to my disappointment, the rack was not stuck and the plastic housing was smooth so the rack was able to slide normally. After I assembled everything again, it started to my surprise, and I drove a few miles with it, gears changing nicely, and then suddenly it got stuck on the second gear and was not pulling anymore, only revving, and it was not possible to put it into any gear after that. It hasn't started since, and I am not sure what the problem could be. The gearbox shaft, that is going into shift actuator, seems to have a mind of its own, its moving up and down when the ignition is on, maybe that is normal, I don't know. Maybe some of you had similar problems and could drop me a hint what to do in this situation. I had it put on diagnostics, I got some codes about solenoid and incorrect data from the ecu. It is probably down to electronics more than mechanics I guess, but maybe some of you have some thoughts about it, I would greatly appreciate if you could share them here. Thank you.
#9 lasse1955
lasse1955
    Newbie
  • Pip
  • 8 posts
Posted 20 March 2011 - 09:20 AM
I wish I could say what the problem is, but I can’t. I agree with you that it is probably down to electronics more than mechanics. Some hint is that the gearbox shaft, which is going into shift actuator, should not be moving up and down all the time when the ignition is on.
When my rack was stuck, the motor was "humming" 4 or 5 times as it tried to turn the actuator and then it "gave up" as it didn’t succeed.
Also motor number 2 turned, as it "tried to help" motor no 1 to put in a gear. After that they didn’t turn any more while the ignition was on, until I switched of the ignition. When I turned on the ignition again then they behaved the same way.
Every time I pushed or pulled shift stick, the motors behaved like I described above and then they didn’t move any more until I moved the shift stick again.
If your actuator behaves like this it dosen´t succeed put in the gears for some reason. If so, there may be some mechanical trouble anyway.
I wish you luck.
#10 koslanski
koslanski
    Newbie
  • Pip
  • 2 posts
Posted 23 March 2011 - 03:34 PM
Thanks for your reply, my problem does not seem to be stuck gear actuators, as they can move easily within their constraints, but the clutch actuator/TCU might be another problem. I took it out, checked for any loose connections, did a bit of soldering, put it all back together, bled the actuator and the car does not start now at all. But when ignition is on, it seems to find gears and change them properly. I was joking with my friend, we will probably be the only or some of the very few people who have actually opened the clutch actuator unit :) Maybe sounds like too much of DIY stuff going on, but anyway, after all this I guess I will still have to go to dealer and get something serious done to the car in order to drive it again. But now I can vouch for the mechanical part of it, it might only be something in the electronics, if the ECU or TCU has got errors in it, then I have no way of solving that in my driveway :). Anyway, I will let you know what I ended up doing to make it work.
#11 Juraj
Juraj
    Newbie
  • Pip
  • 1 posts
  • Ford Model: Fusion 1.4 TDCi
Posted 23 March 2011 - 09:46 PM
#12 judas
judas
    Newbie
  • Pip
  • 5 posts
  • Ford Model: ford fiesta 53 reg
Posted 18 May 2011 - 03:16 PM
I think I had the same problem. My car would drive ok until I hit a round about and would want to switch between 2nd and 3rd gears and stay in between and then would not kick into gear quickly. Then kind of slow down a bit. I broke down when I was going down a road and when it was time to go from 2nd to third it slowed down and stopped. The dash was not reading gears or even starting. You guys think its the actuater?
#13 simpledan
simpledan
    Member
  • PipPip
  • 22 posts
  • Ford Model: mondeo
Posted 09 June 2011 - 10:01 PM
this thread will save someone alot of money. good job
#14 jaw
jaw
    Newbie
  • Pip
  • 3 posts
Posted 27 August 2011 - 09:47 AM
It feels so good!
Cost? Nothing!
#15 jaw
jaw
    Newbie
  • Pip
  • 3 posts
Posted 27 August 2011 - 10:04 AM
HI,
YOUR POSTING IS FANTASTIC AND VERY HELPFUL.I AM USING YOUR POST TO REPAIR GEARSHIFT CONTROLLER.YOU SAY TO MARK POSITION OF RACK BEFORE REMOVING MOTOR AND PUSHING SLIDER.UNFORTUNATELY SOMEONE HAS HAD A GO AT THIS BEFORE ME AND DID NOT MARK THEIR POSITIONS.IS THERE ANY WAY I CAN STILL MATCH THESE POSITIONS SO THEY ALIGN CORRECTLY AS SLIDER IS NOW LOOSE,I JUST DO NOT KNOW WHAT POSITION IT SHOULD BE IN WHEN I CONNECT MOTOR.
