mandybill56 Posted February 8, 2011 Share Posted February 8, 2011 when i fill up water bottle in engin it goes into foot well of passinger side,as any one any ideas as to why Quote Link to comment Share on other sites More sharing options...
taffg Posted February 8, 2011 Share Posted February 8, 2011 when i fill up water bottle in engin it goes into foot well of passinger side,as any one any ideas as to why hi do you mean water bottle as in wiper wash, or water bottle as in expansion tank for your engine cooling system. if its the later then most likely you have a leak in your heating fan matrix in the car. you should have two rubber hoses going from the engine compartment to the rear bulkhead then inside the car to the heater matrix, check your hoses for splits or loose connection. Quote Link to comment Share on other sites More sharing options...
mandybill56 Posted February 9, 2011 Author Share Posted February 9, 2011 hi do you mean water bottle as in wiper wash, or water bottle as in expansion tank for your engine cooling system. if its the later then most likely you have a leak in your heating fan matrix in the car. you should have two rubber hoses going from the engine compartment to the rear bulkhead then inside the car to the heater matrix, check your hoses for splits or loose connection. Quote Link to comment Share on other sites More sharing options...
mandybill56 Posted February 9, 2011 Author Share Posted February 9, 2011 thank you very much for your reply will check this out ,yes it does come from the cooler bottle. Quote Link to comment Share on other sites More sharing options...
