pdoherty89 Posted February 8, 2011 Share Posted February 8, 2011 Hi everyone, i've searched around the topics but my issue seems to be slightly different to everyone elses. I have a 2009 Focus Zetec with a 6000CD player. I previously had my iPhone 3GS connected to my car via bluetooth and it worked fine, but I accidentally selected 'forget this device' on my iPhone a few weeks back. The other day I went to re-connect my phone but it wouldn't pick up the car. I've tried my brothers sony ericsson to see if it's my phone or the radio but his bluetooth wouldn't find the car either. I've looked through the menu and can't find any option to turn the bluetooth on/ off? Also i've now realised the voice control button behind my steering wheel has stopped working? Can anyone help? Phil. Quote Link to comment Share on other sites More sharing options...
pdoherty89 Posted February 8, 2011 Author Share Posted February 8, 2011 For anyone having the same problem, i've seen a response to my problem whih i'll try tomorrow. 'Take off the lower side panel on the drivers side,locate the bluetooth module thats on a bracket underneath the heater. if you open your glove box you will see in each corner a small flap lift the flap and remove the 4 torx screws pull the inner liner of the glove box out and look up and you will see a small square box bend the box down towards you and remove the multiplug,wait 15 mins and reconnect turn on the radio and press the voice button on the stalk and wait for the voice command you phone will have to be rebonded to the bluetooth module go to settings on your phone and search bluetooth devices it will find ford audio then it will ask you to bond with ford audio press yes. it will then ask you for a pin number this is 4zeros and then you are in.the plug and unplug procedure on the module may have to be done a few times so dont refit the glove box untill u make sure the voice control button is working Its a software glitch apparantly.' 1 Quote Link to comment Share on other sites More sharing options...
