moggy Posted February 14, 2011 Share Posted February 14, 2011 Hi.My 2005 1.4tdci Fusion 30,000mls. I am having a problem with this car and running out of ideas. It is hard to start but when it does it will restart quite easily. It ticks over well revs ok sounds good but when you try to drive it is almost dead. Hardly climb a hill in any gear, wont drive on level ground above 40 and has no power at all. When plugged in all is well with no code faults. The fuel pressure readings are ok. egr. maf,fuel filter have been swapped and are fine turbo seems ok. Tried it with cat disconnected from manifold still no change. No water/oil mix no excessive smoke!! At some point the injector seals have been done. I have blown back the fuel pipes to the tank and although there may be a few air bubbles in the lines when you hand prime with the bulb there are no more than my in wifes 206 hdi and it runs corectly. Anybody got any ideas.. THANKS John Ps does this car have a lift pump in the tank??? Quote Link to comment Share on other sites More sharing options...
