Parasidic Battery Drain
5 replies to this topic
#1 philsey
philsey
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: fiesta 1.4 si
Posted 14 February 2011 - 09:03 PM
hi all, i have a 1996 fiesta 1.4 si and have a really annoying problem, if i leave my battery connected overnight, by the mornin my battery is dead, ive changed the alternator,removed the stereo overnight and various fuses even the factory fitted alarm still to no avail, has anybody got any other ideas? im not exactly a mechanic and defo not an electrician, can faulty relays cause this??? any help would be grately appreiciated :)
Have something to contribute?
#2 taffg
taffg
  • New Member
  • 503 posts
  • Ford Model: focus 2.0 zetec Mk 1
Posted 14 February 2011 - 09:13 PM
there are several different earth straps around the engine bay and rest of the vehicle although i cannot exactly advise where, have you got a haynes or maybe someone one the forum may be able to help out. i would remove all these in turn, thoroughly clean contacts with wire brush and refit ensuring a good tight connection.
#3 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,559 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 15 February 2011 - 04:13 PM
did you get the battery drop tested for any dead cells?
#4 btmaldon
btmaldon
  • PipPipPipPipPip
  • 2,587 posts
  • Name: Bruce
  • Ford Model: KA Edge, BMW 320i Coupe M Sport
  • Year: 2015
Posted 15 February 2011 - 04:16 PM
Have you got a light in the boot and are you sure its shutting off when the boot is closed?
#5 philsey
philsey
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 15 February 2011 - 05:21 PM
I removed the bulb incase it was that but still hasnt helped
#6 fishpond 47
fishpond 47
  • 363 posts
  • Ford Model: mk3 mondeo x2 + a ka
Posted 15 February 2011 - 06:06 PM
As said above 'have you had the battery tested?' if yes then put a volt meter across the battery without anything switched on and you should see the volts dropping slowly, go through everything you can (maybe pull each fuse, one at a time) till the volts stop dropping, when you find which fuse stops it then work on that line, ie: if it's the radio fuse and it's stopped dropping when you pulled that fuse then the short is on/in the radio wiring.
hope this helps.
Not what you're looking for?
