Support the club!
Vibration/Shudder when idle/Power Loss
4 replies to this topic
#1 gaz1250
gaz1250
    Newbie
  • Pip
  • 7 posts
  • Ford Model: LX
Posted 17 October 2008 - 06:44 PM
Long story but here goes....got a focus 1.6 it was runnin perfect until the other week when it started to misfire new coil but no diff so turned out to be water in the spark plugs (a think that came from the engine bay being cleaned) changed the plugs and leads and got rid of all water. 2 days later the car struggled to start when cold and then temp sensor went...so after replacing the sensor the cold start problem went and no water returned sorted but now the car vibrates when idle (sat at lights etc) and gets worse when you use your lights, wipers etc. Help this car is drivin me mad!!! Thanks in advance
#2 gaz1250
gaz1250
    Newbie
  • Pip
  • 7 posts
  • Ford Model: LX
Posted 18 October 2008 - 04:05 PM
Just had another look at noticed a noise from the alternator? Could this cause vibrations?
#3 mintalkin
mintalkin
  • PipPipPipPipPip
  • 3,330 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 20 October 2008 - 02:46 PM
check your voltage from the alternator as low voltage will have a knock on effect
#4 Matt_focus_zetec
Matt_focus_zetec
  • 152 posts
  • Ford Model: Focus
Posted 25 October 2008 - 12:17 PM
yoooooooooooooooooooooooooooooooooooooooooo
this is where you need to look through the forum and notice matty boy here had this problem and changed everything on the engine to find out
der der derrrrrrrrrrrrrrrrrrrrrrr
IT WAS THE FORD PCM COMPUTER check out my post focus stalling i think or soemthing like that i had it reprogrammed for £44 quid i think no big deal but car will only do it now when it slows down not when idleing and it only does it for liek a second
Cheers
Matt
#5 Matt_focus_zetec
Matt_focus_zetec
  • 152 posts
  • Ford Model: Focus
Posted 25 October 2008 - 12:18 PM
http://www.fordowner...?showtopic=1652
check out that
