Keycode
4 replies to this topic
#1 nicoconnect
nicoconnect
    Newbie
  • New Member
  • Pip
  • 2 posts
  • Ford Model: tourneo connect
Posted 16 February 2011 - 05:56 PM
Hi.
I recently changed the battery on my Ford Transit Connect
and now the CD 6000 is asking for a code? I donīt remember getting one in the first place so please could somebody tell me where to get it or what it may be
Serial Number: T214232
Thanks in advance
Nico
Have something to contribute?
#2 taffg
taffg
  • New Member
  • 503 posts
  • Ford Model: focus 2.0 zetec Mk 1
Posted 16 February 2011 - 09:07 PM
Hi.
Thanks in advance
Nico
i dont know of a serial number beginning with a 'T', so if you have posted wrong, the code for M214232 is 9602, however if the code is off your radio ident on the rear of the radio i cant help you i'm afraid.
#3 nicoconnect
nicoconnect
    Newbie
  • New Member
  • Pip
  • 2 posts
Posted 16 February 2011 - 09:20 PM
Where would I find the serial number, the one I gave was a number I found attached to my spare key and it is a "T"??? And I live in Spain, would that make a difference??
And yes, I a woman ;o)
#4 mintalkin
mintalkin
  • True Ford Enthusiast
  • PipPipPipPipPip
  • 3,550 posts
  • Name: mintalkin
  • Ford Model: mondeo tdci 130
  • Year: 2006
Posted 16 February 2011 - 09:34 PM
you will need to remove the radio and look for a seriel number beginning with M followed by six numbers, get this and post back with the seriel number.
#5 taffg
taffg
  • New Member
  • 503 posts
Posted 16 February 2011 - 09:41 PM
well 'nicoconnect' yes i am a woman! :)
you can try and press channel numbers 6 and 1 together, or 6 and 2 together this may display some data on the radio screen, write this down and see if it contains the serial number starting with the letter 'M' followed by six numbers, if you are lucky and the code is displayed in the data then repost this number and someone can help you out. if not you will need to remove the radio from the console using radio keys which are usually available in good motor parts shops. ensure you get the correct keys for your radio and they should be very cheap. on the rear of the radio you will find the ident plate, on this you will find the serial number.re post as before.
hope this helps
taffg yes i am a man! :)
Not what you're looking for?
