Reverse Gear Problem
20 replies to this topic
#16 briggsy
briggsy
  • Budding Enthusiast
  • 132 posts
  • Ford Model: Fiesta Style+
Posted 23 February 2011 - 08:30 PM
after an hour of driving testing out exactly whatís going on with gears, it seems that i also get the crunch a bit in 2nd as well, im not to worried about it as yet as it hasnít made me miss the gear yet, apart from reverse :)
Have something to contribute?
#17 jasminerobert
jasminerobert
    Newbie
  • Pip
  • 2 posts
  • Name: jasmine
  • Ford Model: 2014 Ford C-Max Hybrid
  • Year: 2014
Posted 03 October 2013 - 11:37 AM
The problem might be caused by two different things. It is caused either by a problem in the linkage or you have a synchromesh problem.
#18 pip1954
pip1954
    Member
  • PipPip
  • 11 posts
  • Name: philip
  • Ford Model: fiesta
  • Year: 2012
Posted 03 October 2013 - 09:10 PM
the problem i have is when i put it in reverse and start to reverse it jumps back out should i take it back to fords?
#19 alexp999
alexp999
  • 3,274 posts
  • Name: Alex
  • Ford Model: Focus Mk3.5 1.5 EcoRattle Zetec S
  • Year: 2015
Posted 03 October 2013 - 10:17 PM
I had the same on my fiesta. Not a fault just a quirk.
Was advised by my dealer not to engage reverse too quickly, hold down clutch for a few seconds before selecting reverse and you should be OK.
#20 Willy
Willy
    1.0 EcoBoost MR165 Mountuned
  • 2,497 posts
  • Name: Willy
  • Ford Model: Fiesta 1.0 Titanium X Midnight Sky
  • Year: 2015
Posted 03 October 2013 - 10:55 PM
As Alex says, sounds like normal operation. Also 1st and 2nd have a device to stop you putting it into gear at a to higher speed, it's to protect the gear box from damage.
#21 Stoney871
Stoney871
    Resident Peacekeeper
  • Super Mod
  • 18,155 posts
  • Name: Clive
  • Year: 2015
Posted 04 October 2013 - 01:52 AM
If you try going down from second to first at too high a speed the first gear has increased resistance to warn you.
Same going into reverse, it's all about protecting the box.
If you continually have problems with engaging reverse try pumping the clutch pedal a couple of times in neutral and try again.
Not what you're looking for?
