themagicrat Posted October 24, 2008 Share Posted October 24, 2008 My 2003 TDCi has started juddering. If I'm driving at about 40mph in 3rd or 4th gear on a part throttle the car stutters as if it's about to run out of fuel. At motorway speeds or in normal acceleration it's fine. Any ideas ? Thanks Quote Link to comment Share on other sites More sharing options...
mintalkin Posted October 24, 2008 Share Posted October 24, 2008 if its happens at about 1800-2000 rpm the most common cause could be the egr valve getting cloged up. you can remove and clean it out to see if it improves things Quote Link to comment Share on other sites More sharing options...
mike4369 Posted November 24, 2008 Share Posted November 24, 2008 if its happens at about 1800-2000 rpm the most common cause could be the egr valve getting cloged up. you can remove and clean it out to see if it improves things Mine has started to do the same but despite cleaning the EGR it has not cured the fault. I have also changed the throttle pedal thinking it may have had a flat spot since I had to depress it about an inch before the revs build , this had no effect, also the juddering starts at the same spot on the pedal whatever gear/speed. Totally confused <_< Quote Link to comment Share on other sites More sharing options...
mike4369 Posted November 26, 2008 Share Posted November 26, 2008 Mine has started to do the same but despite cleaning the EGR it has not cured the fault. I have also changed the throttle pedal thinking it may have had a flat spot since I had to depress it about an inch before the revs build , this had no effect, also the juddering starts at the same spot on the pedal whatever gear/speed. Totally confused <_< Turned out to be a split in the rubber pipe between the turbo and intercooler quote the mechanic "Its a common fault" once changed the car drives like a dream and is doing more MPG (reduced MPG is another symptom). It is poss to DIY fix The pedal issue turned out to be a red herring and I wasted a lot of time persuing it. edit the pipe in question was between the intercooler and the egr Quote Link to comment Share on other sites More sharing options...
mintalkin Posted November 27, 2008 Share Posted November 27, 2008 a split in the intercooler pipe is usually leads to a loss of power due to loss of turbo pressure and black smoke. this is not mentoned in the origanal post. Quote Link to comment Share on other sites More sharing options...
bill1948Libby Posted March 30, 2009 Share Posted March 30, 2009 My 2003 TDCi has started juddering. If I'm driving at about 40mph in 3rd or 4th gear on a part throttle the car stutters as if it's about to run out of fuel. At motorway speeds or in normal acceleration it's fine. Any ideas ?Thanks Hi. Silly question, but you haven't put petrol instead of diesel in it, have you??? I did and suffered exactly the same symptoms. Reckon I was running on a 50/50 mix. Drained tank & refilled with diesel. Everything ok. If you think you might have put petrol in, drain it PDQ, as diesel lubricates pump - petrol doesn't and replacing pump is expensive. Cheers. Quote Link to comment Share on other sites More sharing options...
