ford fiesta heaters
#1
Posted 27 October 2008 - 12:04 PM
#2
Posted 27 October 2008 - 03:48 PM
#3
Posted 27 October 2008 - 06:22 PM
#4
Posted 29 October 2008 - 03:00 PM
#5
Posted 01 November 2008 - 05:25 PM
#6
Posted 23 November 2008 - 12:54 PM
#7
Posted 23 November 2008 - 03:13 PM
I had the same problem with my 2001 fiesta. I've just replaced the heater control valve and it's now working a treat!hi, i have a 2001 mk5 ford fiesta and when i set the blower to hot it still blows cold air i could probably drive to the moon and back and still have cold air any suggestions
#8
Posted 24 November 2008 - 10:05 PM
if its not working,it will remain silent....easy job to replace.
#9
Posted 25 November 2008 - 02:05 AM
Check the coonalt system for any leaks + oil in the system
Check the system for any air locks
Check the head gasket to see if it is gone or on the way out
Check the heater control valve to see if it is faulty
If you have checked all of these there is only 1 possibility:
The only possibility i can think of is that the heater matrix has gone, it doesnt usually go but it sometimes happens. Its worth buying a new one, as they come with warranty and a second hand one will probably go again.
#10
Posted 04 December 2008 - 04:16 PM
I have a 2001 1.8 TDI (Endure DI) - Can someone tell me if the coolant pipe from the top of the engine goes into the Control valve side with the motor on it (right side if you look at it from the front of the car) and the other pipe from the oil cooler then goes into the control valve with no motor on it (left if you are in front of the car looking at it.) I cannot find any pictures of this anywhere and I do not know anyone with the same car to check...!
thanks in advance,
Dave.
#11
Posted 04 December 2008 - 08:32 PM
This has happened to mine twice, both times just as the winter weather is kicking in. Once its had been cleaned, it worked fine.
#12
Posted 08 December 2008 - 11:30 AM
#13
Posted 12 December 2008 - 05:56 PM
