Break Pad Help
2 replies to this topic
#1 The_Guru
The_Guru
    Newbie
  • New Member
  • Pip
  • 6 posts
  • Ford Model: Ford Focus
Posted 10 March 2011 - 05:04 PM
Hi everyone,
Recently my breaks have started sqeeling, I don't think they need replacing because it's more of a grinding noise but has anyone got any ideas/suggestions on what to do or how to check?
Have something to contribute?
#2 fiesta_lad
fiesta_lad
    Area Rep: Northwest
  • New Member
  • PipPipPipPipPip
  • 1,190 posts
  • Ford Model: fiesta mk5
Posted 10 March 2011 - 11:53 PM
Hi everyone,
If your getting a grinding noise this means the pads are worn and and if your hearing a grinding noise your propbaily need to replace the disc best thing to do is check the break fluid level if that is down this can be cause by worn pads next thing to check do a visual check on the pads and check the runout on the disc. what normally happens when your pads get worn is the break fluid will drop but once you replace the pads pump the breake pedal the fluid will rise again.
#3 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 21,041 posts
  • Name: James
  • Year: 2007
Posted 11 March 2011 - 09:31 AM
Squealing tends to be vibration related. if you have sufficient pad left, then buy yourself a tube of "Copper Grease".
Take the wheels off, and remove the breakpads, then copper grease all points of contact between the calliper and the break pad (top and bottom "clip" parts [front and back also]), also copper grease the callipers, and the piston ring that contacts the break pad. I did this and resolved my little "squeal".
Not what you're looking for?
