Speedo Not Working
#1
Posted 11 March 2011 - 01:55 PM
Is there anyway I can fix this?
Regards,
Andrew
#2
Posted 11 March 2011 - 02:26 PM
#3
Posted 11 March 2011 - 02:30 PM
#4
Posted 11 March 2011 - 03:06 PM
from the same reading i have seen that if you carry out the instrument cluster self diagnoses (a pinned topic on this forum) it will help...if it does a gauge sweep its ok, but if not your busted.
i could be wrong, but like i say, its what i have read on several focus forums.
#5
Posted 11 March 2011 - 04:36 PM
From what I remember the known problem with the instrument cluster, which was highlighted in the Watchdog programme, affected the whole cluster, all the gauges froze as well as the speedo.
#6
Posted 12 March 2011 - 07:49 PM
#7
Posted 12 March 2011 - 08:29 PM
#8
Posted 14 March 2011 - 08:14 AM
try the vvs first as its a cheaper repair let the garage do it as they are known to snap in the gearbox this was the fix for mine.The radio volume went lower also the car did not run smoothly whilst the speedo was not working.
Yeah, the Automatic Volume Levelling is the giveaway with this, because its linked directly to the VSS, this may be the one thing we can give to Ford, at least its a (fairly) easy diagnosis if the VSS goes!
#9
Posted 15 March 2011 - 09:48 AM
I've had the same problem with the volume and smooth running at low revs.
I will check the vvs. Thank you!
#10
Posted 15 March 2011 - 06:21 PM
I have just checked the dash using the diagnosis procedure in the sticky. All the dials work fine and the MPH speed reads correct (when the speedometer works) When the speedo drops to 0 so does the digital dial, does this indicate a problem with the VSS?
How much am I looking at to get the VSS looked at and fixed?
Also my check engine light came on this morning (bottom left amber one). related?
#11
Posted 02 May 2011 - 10:38 AM
Had this on my 03 plate - as Ford knew about it the replacement cost me £120 compared to the £400+ that it could have done! Also with mine all the warning lights flashed and looked pretty cool even if it was scary x
#12
Posted 18 July 2011 - 06:13 PM
The lights work but the gauges work intermittently.
The info here is helpful but I have a couple of questions, what are the VSS and the WS and where do I find the info on the diagnostic test.
I read on another website about holding in the reset button (I assume this is the trip meter reset button) and turning on the ignition.
Is this the test?
When I do this there is no readout on the odometer.
Can anyone help?
#13
Posted 18 July 2011 - 07:20 PM
#14
Posted 19 July 2011 - 07:01 AM
#15
Posted 19 July 2011 - 08:35 PM
I found a fix on another forum for the instrument cluster problem. It seems that it is related to damp on the pcb.
I'm not sure how long the fix will work for................... but it does work.
Remove the trim from around the cluster. There are 4 or 5 posidrive screws at the top. The bottom is held by push in studs.
It is a bit tricky to get these out without scratching the cluster front!
There are 4 screws holding the cluster in place, remove these and swing the cluster round.
The white connector on the back has a black locking lever (it's difficult to see how this works).
Pull the lever away from the direction of the cables, over the little block. As this moves it will help push the connecor free.
On the back of the cluster are 2 torx screws and some plastic loops. Remove these and remove the back to expose the pcb.
Spray the pcb with WD40, I used a small brush to spread it over the back and clean the board.
I put the unit in the airing cupbaord overnight, fitted it in the morning and found that it was OK.
If it doesn't work for long it will be easy to replace it, they seem to be available new on the net for about £60.
Better than paying Ford main dealer silly prices!
2 user(s) are reading this topic
0 members, 2 guests, 0 anonymous users
