Mk1 Focus Egr Valve Help
32 replies to this topic
#16 APJ
APJ
  • Budding Enthusiast
  • 234 posts
  • Ford Model: 2005 Ford Focus 2.0TDCI Titanium
Posted 16 March 2011 - 02:54 PM
let us know how you get on....am gona be attempting this on my MK2 2.0TDCI as soon as i have time!
Have something to contribute?
#17 tazz786
tazz786
  • New Member
  • 35 posts
  • Ford Model: 1.8 TDDI Focus 2001
Posted 16 March 2011 - 03:21 PM
Thanks mate. Going to go to a few shops tonight and if i cant find it ill order that. Think ill make a video while i do it aswel for you all
#18 stef123
stef123
  • Management
  • 5,532 posts
  • Name: Stef
  • Ford Model: Mondeo ST TDCI
  • Year: 2006
Posted 16 March 2011 - 04:12 PM
Hi cressws1 - Yes EGR is only related to the diesel engine, the reason is (from my understanding) that the exhaust gasses are recirculated to the engine, and therefore can reduce the amount of Oxygen required for the combustion sequence, this makes it easier for the engine to work as the operating temperature of the engine has been reduced.
Hope this is somewhat along the right lines, any corrections will be happily recieved!
dont know about fords but an EGR valve is not just for a diesel engine. plenty of petrol engines have them, my old mk1 focus 1.6 didnt have one
#19 mross
mross
  • New Member
  • 77 posts
  • Name: Mark
  • Ford Model: Focus 2.0 TDCI 136 Ghia, Powershift
  • Year: 2007
Posted 17 March 2011 - 12:02 PM
Petrol and diesel turbo engines have EGR valves in most cases, regarding the wynnes egr cleaner from ebay i can vouch for this stuff i have used it myself on my focus on my dads peaugeot 206 (both cars turbo diesels)and it works a treat.
#20 tazz786
tazz786
  • New Member
  • 35 posts
Posted 17 March 2011 - 10:53 PM
Hi all,
Ive finally managed to get the spray at a shop called bullseye. Going to do this after work tomorrow now. Just one last question. While im spraying it do i need to rev the car? i think thats what there doing while spraying?
#21 shaddow
shaddow
    Member
  • New Member
  • PipPip
  • 20 posts
  • Ford Model: focus tdci 1.8 edge
Posted 18 March 2011 - 12:49 AM
Yes i think its a two man job. If you look at the E-bay link i sent you above, there are some instructions on there. Will look on here tomorrow night to see how you get on. Mine came today, but will have a go at it on saturday weather permitting. Good luck!
#22 shaddow
shaddow
    Member
  • New Member
  • PipPip
  • 20 posts
Posted 18 March 2011 - 01:10 AM
Ok just looked at the instructions on the advert on E-bay. They are as follows.
Start engine, and run till warm
Set engine to run at 2000 rpm
Spray in short intervals
IMPORTANT, if revs increase whilst spraying, reduce revs to idle
Rpm, and diesel knocking can increase during pulverisation
After each pulverisation, wait for revs to settle
Continue till all the 200mlare consumed
Let the engine run at idle for a few minutes
Turn off engine
Re-attach hose
Re-start engine
After this idling period accelerate the engine 5 to 10 times, or drive for 5 to 10 km
DO NOT EXEED 3000 RPM.
Hope this helps
#23 jeebowhite
jeebowhite
    Resident Loon
  • Super Mod
  • 19,088 posts
  • Name: James
  • Year: 2007
Posted 18 March 2011 - 08:32 AM
Very useful instructions, I thought that the EGR had to be removed, but if it can stay in, even a simpleton like me could do it! good stuff as my MPG is getting a bit crappy now so I will see about trying this!
Maybe we should have a thread tutorial on everything you can do to improve the engine efficiency, everything from the bog basics to the likes of this...
If I do decide to keep my car by the end of the weekend then I will probably blister my car with everything I have and then write up a full thread on it!
#24 APJ
APJ
  • 234 posts
Posted 18 March 2011 - 09:33 AM
it seems as simple as take hose off and spray whole can in while giving the engine a bit of a rev...let us know how you get on tazz, am waiting with waiting with baited breath to see if it goes ok and if you encounter any issues!
#25 tazz786
tazz786
  • New Member
  • 35 posts
Posted 18 March 2011 - 10:31 AM
Thanks all. I will update you all later about this now then. Everything is ready just wanting to finish work so once ive completed it ill post some pics and let you all know if its made any difference. Thanks for all your advice been really helpful
#26 APJ
APJ
  • 234 posts
Posted 18 March 2011 - 11:25 AM
Good luck mate....really hope it works. If it does i'll do mine too!
#27 shaddow
shaddow
    Member
  • New Member
  • PipPip
  • 20 posts
Posted 18 March 2011 - 07:44 PM
Hopefully doing mine tomorrow. Will also let you know how i get on
#28 tazz786
tazz786
  • New Member
  • 35 posts
Posted 18 March 2011 - 09:02 PM
Hi all,
Well ive finally done the clean and...... The car is finally not smoking :D Its worked very good. Improved bhp a little aswel so im more than happy. My car before was really bad for smoking and now theres hardly anything.
Heres some steps to help you all.
http://a6.sphotos.ak...5_6939040_n.jpg
Remove the air flow pipe to your left
Once removed it should look like this..
As you can see the left pipe is now removed.
If you now just clean inside the egr valve with a cloth just to get all the sludge out of it.
Now back to the instructions i was send.
Turn off engine
Re-attach hose
Re-start engine
And thats about it. Once you have followed these instructions you should notice you car running alot better than before. Im really impressed with how simply it was and really want to thank everyone on this forum for you help. Hope my instructions make sense to you all and goodluck with doing it youself. I didnt have any problems doing it. Its really straight forward.
Thanks Again :D
#29 shaddow
shaddow
    Member
  • New Member
  • PipPip
  • 20 posts
Posted 19 March 2011 - 01:14 AM
Well done Tazz. More than pleased my info helped you. Will definatley do mine tomorrow if weather permits. Hope mine goes as well as yours, sounds like its worth doing anyway. If it does,nt fix my problem at least i know it,s not done any harm. Will keep you posted tomorrow.
#30 tazz786
tazz786
  • New Member
  • 35 posts
Posted 19 March 2011 - 08:52 AM
Yeah defo keep us informed. Good luck with yours. I think everyonw shud do the clean really. I got so much crap out of it.
Not what you're looking for?
