Hello all and thanks in advance
I am trying to replace the front OS Suspension arm
Having eventually got the lower nut off the bolt I can not remove the bolt.
It would appear that the sleeve is siezed in the bush
When trying to remove it simply will not budge
Anybody have any ideas?
It is the last job I have to do to put it through a re test and am somewhat stuck
Any advice would be appreciated
Pete
FiestA MK4 fRONT SUSPENSION
Started by peteh8, Nov 01 2008 11:53 AM
3 replies to this topic
#1
Posted 01 November 2008 - 11:53 AM
#2
Posted 01 November 2008 - 02:43 PM
try a 24hr soak with wd40 or duck oil on the sleve.
#3
Posted 01 November 2008 - 03:26 PM
Thanks for that
will give it a try
#4
Posted 01 November 2008 - 03:48 PM
Thanks for that
will give it a try
Also see if you can get any heat into it.
